HI. I've been looking at this site for a while now and I have finally decided I need a little assistance. Im replacing the transom on my 18' 1989 center console wellcraft. The model is a 18fisherman. At this point
I have the cap off and the tank out. All electrial out and Im digging out the old foam. The cap is all one piece. The sole or deck is plywood sandwhich between glass. My plan for that was too just cut the bottom layer of glass out and dig out the wood then epoxy new plywood in. Then glass over that. What type and how many layers of glass do I use to go over that? I will post pictures once all the foam is out. I need to replace the stringers, transom and the floor or sole. Re paint it also. Glass in the center console. I can't decide if I should use foam for the transom and stringers or use plywood. I do not want a rot problem again. If I were to use plywood. I see Meranti ect, but I think I need to find a local place that I can just pick up some wood and save on the shipping. I will purchase the glass from this site. I have some epoxy already. What do you suggest I use for the transom and the stringers? How thick do you think I should make the transom. I haven't cut the inner glass out yet. How thick is the transom usually on a boat like this? The outboard is a 115hp suzuki 4 stroke. The engine is removed. The hull still sits on the trailer. I will try and post pictures today. I live in southern CA.
