MeMalato wrote:I need to get an estimate on the supplies that I will need to put the transom in. First question is a 2" thick transom enough for a 18' center console with a 115hp outboard..
maybe, but it depends on the rest of the structure. Im confused, I thought you were rebuilding with plywood?
Could you please refresh your photobucket account so we can see those pictures? I cant remember the details of this thread.
The fastest way to build the thickness is going to be with 1708, which is all you need if you are going with a plywood core. Witha foam core we would prefer to use two types of biaxial cloth (1708 and LT1700) the second one has fibers running in 0/90 degrees and 1708 runs at 45/45.
You will want to reproduce the original inside skin thickness, 4 to 5 layers of 1708 will give you 1/4"
need to see those pictures
