shine wrote:Thanks for all the pictures. With your permission I would like to use your thread as the basis for a new tutorial on transom repair.
Joel
Sure Joel, I'd be honored. Thats why I documented it, figured it may help others out down the road(or river) needing similar repairs.
Today I drilled out the cockpit self-draining(scuppers) holes. As with the bilge drain, I first oversize drilled it by approximately 1/4". Then I filled it in with an epoxy/fiberglass/wood flour paste, and let it set up. Next I drilled it correct size for brass sleeve to fit in. You can see the 1/8"-3/16" epoxy coating throughout the drilled holes, separating wood transom material from from outside elements.
Next I'm installing brass throughhull sleeves in these openings, after coating holes and outside of sleeves with 3M 5200. That should actually give transom three layers of protection from water reaching wood. First the brass sleeve, next the 3M 5200, and finally the epoxy layer coating holes. I plan to use this method on every attaching screw, hardware, etc., going into this transom, with the exception of adding brass sleeves. Its a little extra work now, but should pay off big time for years to come.
Also sanded and smoothed fairing mix on some of the seams, and part of the transom notch , and added some glazing putty to smooth out some small imperfections. Mixed a small batch of epoxy and added a little white pigment, then painted it over a few of the seams, to see how it looked. Although it settles to a smooth finish, the color was off from existing color, and I'm concerned that epoxy doesn't really adhere that well to existing gelcoat. Local paint supplier gave me a cup of brown pigment that I'm sure I could adjust color to match with.
I'd love to just clean it up, sand it smooth, and paint the complete splash area. I would even consider painting the complete boat, but I don't want to have to repaint every few years. Thats' why I'm torn between just match coloring epoxy and covering only seams and added transom height, smoothing out to edge of existing gelcoat. If I do this, then I can restore existing gelcoat and just keep up with it, and not worry about about recoating in a few years.
Decisions, decisions, decisions. I think I'll be calling BBC and see what the pros think.
