• Sponsored By:
SH14 Forward frame angle
Postby misterpants » Thu Apr 05, 2012 1:32 pm
My first build. I can't figure out how to draw the forward frame at the correct angle from the plan dimensions. I haven't cut anything yet. Thanks in advance. :help: please
misterpants
Sponsored By:
Register to see less of these.
Re: SH14 Forward frame angle
Postby peter-curacao » Thu Apr 05, 2012 2:35 pm
misterpants wrote:My first build. I can't figure out how to draw the forward frame at the correct angle from the plan dimensions. I haven't cut anything yet. Thanks in advance. :help: please
what do you mean what angle?
peter-curacao
Postby misterpants » Fri Apr 06, 2012 8:40 am
On the plan that shows the dimensions of the sides, the line representing the forward frame intersects with the uncut plywood edge (bottom side) 2' 9 1/4" from the tip of the bow. There isn't a dimension measurement specifying where the opposite end of the line intersects the top of the side. The Line's angle on the plan appears to be about 93 degrees to the edge of the plywood. Should I just mark where the bottom of the frame joins the side and angle the frame so it's flush with the top of the side when I get to the step where the two sides are being bent around the frames? Thanks
misterpants
Postby gstanfield » Fri Apr 06, 2012 8:54 am
Repost your question up here: http://forums.bateau2.com/viewforum.php?f=3
Jaqcues doesn't read the non-tech sections very much so it'll likely get missed.
gstanfield
Postby peter-curacao » Fri Apr 06, 2012 11:07 am
difficult to answer (if possible at all)without a drawing
peter-curacao
Postby gianni » Fri Apr 06, 2012 4:56 pm
At 2' 9 1/4" from the tip of the bow, draw perpendicular line (plywood edge bottom side): 7/8 bottom, 1' 8'' rubrail line, forward frame angle ( Approximately 3/4''). Verify the angle (with a level) before definitive assembly of frames.
gianni
Return to Builder's Sail Boats
