I debated a drain plug due to the size of the boat, but took the sage advice of others and will put one in (currently overdrilled to 1-1/2" and filled). Better to have it and not need it than....
I glassed one side of my frames, flipped it, and glassed the bottom last night (a challenge doing it myself wet on wet, but the low temp helped out). I will glass the other side of the frames tomorrow, and that should be it for "required" glass.
I may glass the inside exposed floor, but that will depend on how much epoxy I have left. Currently, I have just under 1/2 of my 3 gal kit remaining. I am pretty satisfied with the amount used so far (bottom tape and cloth put a big dent in it), but there is still a lot to do (I imagine the fairing will consume quite a bit.)
A question for other GF builders: What was your final transom height? because this boat is low sheer intended for smaller waters, I cut the transom down from 20.5 to 15.5", giving me a vertical transom height of just over 15". I thought this would be just right for a "typical" short shaft engine. I happen to have my brother's old '83 Johnson 4.5, so I put it on my boat for a quick check. Turns out it has a 17" shaft length (measured vertically from transom to top of cavitation plate). This puts the cavitation plate about 2" below the bottom of my hull. He still has the original owner's manual, and it specifies this motor for a 15" transom.
Not satisfied with that, I did a search of several current motors (yamaha, tohatsu, mercury, etc.). It turns out that most of their "short shafts" vary in vertical transom height from mid-16" to low-17", atleast in the 8-15hp range.
From what I have read here, the optimal height of the cavitation plate is even with the bottom of the hull (or just slightly below for a GF.
My question is, should I build up the transom now, or see how it performs first?
I don't have a new motor yet, but I hope to get something in the 8-10hp range in the spring. I appreciate any tips.
