CV16 Caravelle - KS8 - more pictures added
Re: CV16 Caravelle - KS8 - more pictures added
Postby ks8 » Thu Nov 19, 2009 2:48 pm
Week old pictures... caught some time to catchup with older pictures. :) 20091118
Grinding out the *bubbling* on the port rail cap.
More than I wanted to have to do... almost half the rail...
The disease spreads
Grinding it all out...
Leveling the result with a dremel and sanding drum, carefully, in prep for finalizing with the RO.
Ready to mask and reseal with epoxy.
Masking for epoxy.
Resealed looks better now already!
Bubbles be gone... after all that picking out white paste dust from sanding, it was worth it. No white dots all over the rail. :)
Back to the Tabernacle Pivot Assembly... starting to glass 'em forever.
ks8
Old Salt
Old Salt
Postby cape man » Fri Nov 20, 2009 9:55 am
I have some "bubbling" on the port side of my gunwale that I need to do the same thing to. Looks like fun :cry: :cry: How are you with the end result?
Old Salt
Old Salt
Postby ks8 » Fri Nov 20, 2009 2:48 pm
Well, there are four issues I can think of...
1- You probably need to bring the glass all the way down to wood in the bad areas, if it is bad like in my pictures.
2 - This means you need to feather it so that you can leave the glass that has no bubbling problem (yet). I used a very light touch with the dremel, in many passes, to take down the large bubbling areas of glass faster than the ro, and then I finished it off with the RO with 120, to fair it a bit, and finally 100 by hand as prep for the seal coat.
3- There is the possibility that the sanding dust may find its way into very small pits or craters. Vaccum this out dry, and or blast it out with compressed air. Do this BEFORE you do any sort of alcohol wipe to see how it will look resealed. I used alcohol because it evaporated much quicker than water, but it does have some water in the 70%, so it needs an overnight dry before resealing with epoxy. If you do not remove all the dust before the wet wipe (or damp wipe), the dust turns into white paste and works its way into those small pits and craters, and it doesn't go clear. Ugh! :x I got most of it out with a straight pin, enough so that what remained did go transparent. :D
4- And finally, will the refinished surface get weird uneven once it heats up in the sun? Don't know yet. And at this point, I'm not worrying about it.
Now, if you've got the urocel on there already, then of course you've got to properly feather in your epoxy resealing and urocel protection when the rest is done. Since I had not LPU'd the rails yet, I didn't have this issue to deal with, and I think I'm going to redo the stbd rail also before the clear LPU hits it.
Hope that helps. Post some pictures on your thread. :D
As I said in the earlier post, it looks MUCH better than it did, though I was hoping for a little better, but it is still plenty good now. :)
ks8
Old Salt
Old Salt
Postby cape man » Sun Nov 22, 2009 9:52 am
I'll post pics when I get a chance to start working on it. May be awhile.... :D :D Living with it for now, as I have to point it out to most people.
Old Salt
Old Salt
Postby chrisobee » Sun Nov 22, 2009 9:58 am
cape man wrote:I'll post pics when I get a chance to start working on it. May be awhile.... :D :D Living with it for now, as I have to point it out to most people.
Well you dont HAVE to point it out... :D
chrisobee
Old Salt
Old Salt
Postby cape man » Sun Nov 22, 2009 10:12 am
I've stopped as of now. :lol: :lol: :lol:
Old Salt
Old Salt
Postby chrisobee » Sun Nov 22, 2009 10:19 am
Please pardon the mini hi-jack but this issue is one that I am currently suffering. I'm kind of stuck doing fairing and everytime I think I've put on the last bit of primer I see a whole series of flaws that must be fixed, and it never seems to end. Now when other folks look at the boat they get this sort of glazed look and say wow.... and most of them can't even understand how its possible to build a boat. I think when you are so personally, involved in a project like this you will allways see the flaws rather than the glory.
chrisobee
Old Salt
Old Salt
Postby ks8 » Sun Nov 22, 2009 2:42 pm
When I did a less than ideal paint job, it was still good to know that underneath it was , glassed, sealed, faired and primed well, and thoroughly, particularly the bottom. :D
ks8
Old Salt
Old Salt
Postby ks8 » Wed Dec 09, 2009 12:50 pm
In case anyone is interested, a performance sail option rig change question was posted here.
ks8
Old Salt
Old Salt
Postby cape man » Tue Jan 12, 2010 8:25 pm
Where are you? Too cold to move?
Old Salt
Old Salt
PreviousNext
Return to Sail Boats
