In looking at the the PG25 for use in rough water and maximum rigidity in all conditions I have considered using double bias +-45/45 as one layer and 0/90 degree biax for another. I am hoping that by using this schedule I will have strong longitudinal strength from the 0/90 and latitudinal strength from the double bias. I am planning on using this on the bottom as well as on the inside bottom before installing the stringers and frames. I believe that I will increase the structural strength as well as the rigidity of the boat and add strength to the monocoque structure for many carefree years of enjoyment. At times on the Gulf we have very short period rough water that are not ground swells. If I am wrong in my assumptions please tell me, as I see this as an enhancement to the longevity of the boat by having a stronger hull with less movement in the structure itself thus less stress to the hull.
HWS
