Here's a little history. I hit something in the gulf a few years back(turtle I believe), it developed a crack alongside the chine in bow area. I cut the hull open in that spot and found it to be an open space inside, under the stringer, I dried it the best I could and then pumped it full of West epoxy/filler(hull thickness is solid 3/8"). The next year the crack came back so I took it to a professional boat repair co. in Pensacola. They took out the inner front fish box, it opened up the entire inside of the hull between the stringers up to the bow. They ground and layed glass/polyester resin(built it up about 3/8").
The next year I got the $##@*&# termites. Did the rip down to find the stringers were indeed delaminated and wet/rotted and not completlely bedded to the hull in alot of places(I don't get it, some boat builders let this sort of thing happen). I would imagine there was some flexing going on for years.
I've had spider cracks in that area before, but I haven't noticed the lateral cracks before I started the rip down. As for the dirt in the cracks, I probably wiped the dirt into the cracks.
I will take all of your advice and do some grinding and inspection. I've done alot of work on the boat allready, this shouldn't stop me.
Stay tunned.
