My FL 14
WHP
My FL 14
Post by WHP » Thu Dec 15, 2016 1:54 am
I got the plans a few weeks back and started building my FL 14.I just gave the bottom of the hull a coat of epoxy .Do i have to sand it before putting the fibreglass sheet over the hull? i, not building a skeg ,just some rails to help protect the bottom of the hull. What size( if possible in metric) should the rails ( don't know if rails is the correct word for it) be and how many should there be? Are the going the whole length of the bottom?
WHP
Re: My FL 14
Post by WHP » Sat Dec 31, 2016 4:36 pm
I found in the plans the size for the rails . I did already a lot on the boat put some pictures in an album. Have a lot of sanding to do
Re: My FL 14
Post by jacquesmm » Sat Dec 31, 2016 5:18 pm
I call them runners but the name does not matter.
Exact size does not matter either: about 25 mm square.
You need either a skeg or runners for tracking: you can't row straight in string winds without them.
WHP
Re: My FL 14
Post by WHP » Sat Dec 31, 2016 6:49 pm
If all goes correct i have it n the water by end of Jan or beginning Feb. Still working on a name :D
FL 14
Re: My FL 14
Post by Jeff » Sat Dec 31, 2016 7:04 pm
Nice WHP!!! Is this the first pictures of your build?? Jeff
WHP
Re: My FL 14
Post by WHP » Sat Dec 31, 2016 7:43 pm
Jeff there are some more pictures in the Gallery . :D Peter
Re: My FL 14
Post by Jeff » Sat Dec 31, 2016 8:06 pm
Ok and thanks WHP!! Jeff
WHP
Re: My FL 14
Post by WHP » Mon Jan 02, 2017 5:36 pm
Gunwale on both sides is done sanded it . Set a smal board in to the bow to store the ancker, chain and rope. Next I drill holes for cleats and rod holders so I can seal the holes .
I,m brushing the whole boat with epoxy , do I still need a paint primer( undercoat ).
http://forums.bateau2.com/app.php/gallery/image/333
http://forums.bateau2.com/app.php/gallery/image/334
Browndog
Re: My FL 14
Post by Browndog » Mon Jan 02, 2017 7:41 pm
Looks real good. Congratulations and keep it up.
Re: My FL 14
Post by Jeff » Mon Jan 02, 2017 8:37 pm
WHP, looking really nice!! Very good gallery!! Jeff
