payson joint using a warped piece of ply
ahinkle
Post by ahinkle » Mon Feb 27, 2017 12:19 pm
I would like to joint to pieces of ply to make my bottom panel for my R13, but one piece or ply (click link to pic) is warped. What can I do to make a nice payson joint?
https://goo.gl/photos/3G3kutLxwDGUz9Sf6
Re: payson joint using a warped piece of ply
Post by Dougster » Mon Feb 27, 2017 1:27 pm
Lay panels over a few lengths of 2 x 4's, with one underneath the joint. Lay plastic between panel and 2 x 4s at joint. Screw panels down thru 2/4's and glue/tape joint. Heavy wieghts help too. Flip and tape other side. I dunno if that's a payson joint though.
Post by jacquesmm » Mon Feb 27, 2017 1:52 pm
http://bateau2.com/howto/long_panel.php
I specified this in my plans well before Payson renamed it. It is a simple fiberglass splice: join 2 pieces by putting a piece of fiberglass tape over it.
Now, watch out with some of my designs. I often use the butt block as reinforcement.
In the R13, the butt block is just under the mid frame. It is a reinforcement.
Do not replace ti with a fiberglass splice. If you do, add the butt block on top of it.
ahinkle
Post by ahinkle » Mon Feb 27, 2017 6:36 pm
Thanks Dougster and Jacques!
Users browsing this forum: NEWZEALANDNEWBIE and 1 guest
