Bad Mix of Foam?
Re: Bad Mix of Foam?
Post by BB Sig » Sat Mar 09, 2019 4:31 pm
Fuzz wrote:
Sat Mar 09, 2019 3:45 pm
I would not sweat it, just pore more foam to fill it up and move on.
This I can do. This little boat needs to be in the water! :lol:
Post by BB Sig » Sat Mar 09, 2019 5:54 pm
Moved on and poured more foam! :D
Post by fallguy1000 » Sat Mar 09, 2019 7:13 pm
Gg.
Looks like a few spots are just tempermental.
Build on sir.
Post by BB Sig » Mon Sep 16, 2019 9:22 pm
Sealing foam question....
If I am pouring foam onto cut foam, should I seal the cuts with epoxy first or is it safe to pour foam onto the cuts and then seal what's left?
See the picture below of a channel I cut in the foam. This is specifically what I am asking about. :help:
Post by Capt UB » Tue Sep 17, 2019 6:01 am
Barry after the same problem with my foam pour, too hot outside, too hot of boat and too hot of a foam mix it shrank. I had the boat out in the sun and had the two parts of the foam out there too. I will never do that again.
Anyway, I was testing the foam (inside room temp) and brushed the foam mix onto the old (few months old now) foam to see if it would stick. It did, next I mix another small batch brushed the old foam and covered it with plastic sheet a piece of plywood on top. Sealed and looked very clean. This may work for you. Cool foam mix, brushed on cool surface and covered. The brush puts down a very light coat. Have everything ready before you start. Good luck....
Bob.
Post by BB Sig » Tue Sep 17, 2019 7:54 am
Thanks! :D
Dutch1
Post by Dutch1 » Tue Sep 17, 2019 10:35 pm
X2
