V12 fiberglassing question
Re: V12 fiberglassing question
Post by Jaysen » Fri Oct 25, 2019 4:56 am
One is easier to bend. Get that one. The v12 hull gets very curved forward of mid frame. You need the flexible ply.
Or lots of liquor. Both for nerves and wounds.
Class Mini 580 welcome post.
Post by Jeff » Fri Oct 25, 2019 8:09 am
Ant, The Okoume BS1088 (Should be Lloyd's Stamped & Certified) is the best Marine Plywood. The Okoume BS1088 is a little lighter and easier to bend. The Okoume BS1088 marine plywood is made in France. The Meranti BS1088 is not Lloyd's certified, a little heavier & stiff. The Meranti is made in Malaysia. Still a good marine ply, just not Okoume. I hope this helps, Jeff
Post by terrulian » Fri Oct 25, 2019 9:19 am
I didn't have a good source for Okoume so used Meranti, which still bends easier than fir marine ply. Not sure I follow the price difference you quoted but with the Meranti I had a hard time getting the bend right at the bow on my V10 and would have sprung for the difference even if 50% for the Okoume. It wasn't an option for me but since the only difficult bend is at the bow, if you had enough for that section only, which I think would only be 1 sheet, you could use Meranti for the rest. It's unlikely anyone on the forum is going to recommend hardware store marine ply.
Post by Dougster » Fri Oct 25, 2019 10:51 am
I used Meranti for the LB22 some years ago. It was a pita getting the bow bend until Jacques said to kerf it. That did the trick. Actually I cut slits 2" wide along the front 3' or so of the side panels. Made the bend easy but a pain to fair. Still, it worked fine.
The next build was Ocoume and life was a bit easier.
Post by Jaysen » Fri Oct 25, 2019 11:27 am
Jeff, what did I get for Lil Bit?
I ask because the bow was a b!tch for me as well. If we all use meranti, then I would tell you go with the okoume. If I build another v12 (which I very much want too) I would buy the okoume.
Post by Jeff » Fri Oct 25, 2019 12:15 pm
Jaysen, both of the V10 & V12 are cut from Meranti!! It is an option to upgrade and I agree that the Okoume is much more flexible. But Meranti is a great marine plywood!!! Jeff
Post by Jaysen » Fri Oct 25, 2019 3:16 pm
Jeff, not questioning the quality of meranti. But from a practical point, the bow of the v12 really wants something easy to bend. If the cost of okoume isn’t prohibitive to the builder it will make it easier to get a pretty bow.
Post by Jeff » Fri Oct 25, 2019 4:00 pm
I will talk with Jacques!!! I fully understand your point!! Jeff
Post by terrulian » Fri Oct 25, 2019 7:57 pm
This is what I needed to do to get my bow together with Meranti.
