FS14 Question for Jacques
Post by Jeff » Tue May 12, 2020 7:46 am
This question arrived via email last evening: "Sounds good. If I might just get your opinion on something. I want to include a sprit rig on this build to sail approx 25-30% of the time, but mostly run on plane up in the delta above Mobile bay. So should I include a daggerboard and box, or simply a larger than normal keel for the part when actually sailing?Thanks" Jeff
Re: FS14 Question for Jacques
Post by Jaysen » Tue May 12, 2020 8:18 am
I think a useful keel would create too big of a skeg for planing. Also, the use of a dagger allows JM to ensure that the COF is aligned. Basically... if you want to sail "wellish" use the dagger.
That said, that dagger slot will become a fountain (if it behaves like mine) once you run the motor up. Put a cap on it when not sailing. Alternatively, JM might recommend leeboards. That would be a solution to all the problems if he says it will work...
Class Mini 580 welcome post.
Post by jacquesmm » Tue May 12, 2020 9:34 am
The FS14 is a power boat and will not sail well. You could have a rig for emergencies but any appendages like keel, dagger board or skeg will seriously handicap the performance under power.
I hate leeboards: I learned to sail on boats with leeboards (in Holland) and only dreamers who never used them will like leeboards: nothing but troubles.
