3D image of FS14LS, Jacques?
VT_Jeff
Post by VT_Jeff » Tue May 12, 2020 12:48 pm
Is it possible to get an svg or other 3D image of the FS14ls I can use to help with a trailer design?
Thanks,
There are only two seasons in Vermont: boating season, and boat-building season.
Re: 3D image of FS14LS, Jacques?
Post by jacquesmm » Tue May 12, 2020 2:16 pm
I don't like to give out 3D models but you can quickly build one using the stations drawing from the plans.
For a trailer: use the shape of the stringers, that is very simple and bunks will fit perfectly.
VT_Jeff
Post by VT_Jeff » Tue May 12, 2020 3:00 pm
I'll try that, thanks. I'm building a Franken-trailer for the boat and motorcycle for our long trips. Trying to determine exactly how they will interface is the challenging part.
This is what it looks like for the driftboat setup.
This is just a bottom-of-the-line Tractor Supply trailer to which I added a red-neck MC carrier, bunks, bow stop, winch and converted the tounge to a longer A-frame. For the FS14LS, I'm going to use a much wider axle so that the MC and boat will both be within the fenders, this is a 3d rough sketch:
As always, any opinions welcome.
VT_Jeff
Post by VT_Jeff » Thu May 14, 2020 12:22 pm
It was "fairly" easy.....Not perfect but allows me to visualize the boat and bike on the trailer.
Post by jacquesmm » Mon May 18, 2020 2:23 pm
You have the plan and profile, that gives you all the dimensions you need. There is no need for a 3D model to construct some hull blocking on the trailer but if you want it, it is easy to rebuild the whole 3D shape from the plans. Start with our baseline, add the frames and transom and you have a full lines plan in 3D. It should take a good CAD operator about 10 minutes.
I understand that it fun to play with a 3D model, I do that too even when it is no necessary: from parts for my boats to garden planters.
