Sintes 21 Rebuild
Re: Sintes 21 Rebuild
Post by Fuzz » Sun Mar 19, 2017 9:47 pm
Well I got around to pouring a little foam in between the stringers. I used about a quart and thought this is not going to ever fill the space, maybe it is too cold :doh: So I take my turkey fryer and warm some water up to about 120f, pour it in a cooler, put a gallon of foam in the cooler and let it heat soak for about 15 minutes.
It was like I was using a totally new product. When I poured the clear part into the mixing cup it was foaming just a little. When I added the dark part B I had about 5 seconds of stirring before the chemical reaction started. Maybe it was a little too warm :doh: I will say I got a lot more expansion than what I am used to. Anybody know the ideal temperature for this stuff?
Post by Jaysen » Sun Mar 19, 2017 9:57 pm
Put one in the hot water, the other outside... shoot for the middle :P
Post by Eric1 » Sun Mar 19, 2017 9:57 pm
Glad you are back at it. Good idea to water bath the foam.
Post by Fuzz » Sun Mar 19, 2017 10:02 pm
I had it sitting in front of the shop heater. It was probably about 70f. boat is around 60F, best guess. I thought I read 85f was a good temperature so that is why I tried the warm up deal.
Post by Fuzz » Tue Mar 21, 2017 1:43 am
Ok need a little input. What size chase tube for two #10 wires. Also size for fuel line and any other stuff. I have a roll of 1 inch and a roll of 1/2 inch flex conduit.
Also is it better for control cables to exit the transom straight on or from the side?
Thanks guys :D
Post by cape man » Tue Mar 21, 2017 6:46 am
1".
AmbitiousRookie
Post by AmbitiousRookie » Tue Mar 21, 2017 4:21 pm
I don't have my uglys reference handy but think it's 6 #10 wires in 1/2 emt.but that's get I think a little tight if you have to pull more. Bigger always better unless it's emt and your the one bending it lol
Post by cape man » Tue Mar 21, 2017 4:29 pm
My choice was based on having to pick from big (1") or small (1/2"). Ask me how I know you can run a chase that's too small.... :roll: :roll: :oops:
Never again. You have plenty of space for the larger tubes.
AmbitiousRookie
Post by AmbitiousRookie » Tue Mar 21, 2017 5:17 pm
So we don't like 3/4 :lol: I know what you saying I was only pointing out If I was telling someone else do it i always went bigger if I did it I weight the pro and cons a little closer 1" would kick my butt sometimes running 500or600 ft bending around everything.
Post by Fuzz » Tue Mar 21, 2017 11:08 pm
Ok what size for shift/throttle cables? I will have three 90s, long sweep, in the line.
