1984 Grady 242 Caribbean Transom Repair (+ other stuff)
Re: 1984 Grady 242 Caribbean Transom Repair (+ other stuff)
Post by Fuzz » Wed Jun 13, 2018 12:23 am
I use mine all the time. At this point trying to build without one would be about imposable.
I have the rockwell sonic crafters. I am on number 2. The first one was an original one with the hex head bolt to attach the blades with. I was glad when it died so I could get the latest and greatest model. It is an F-50. I think there is an F-70 out now. The newer one is a far better tool and easier to use in all ways.
Post by fallguy1000 » Wed Jun 13, 2018 9:50 am
My current HF oscillates in multiple ways. The engine rpms are oscillating now.
:doh:
DAYTRIP
Post by DAYTRIP » Wed Jun 13, 2018 8:49 pm
If you use a sharp chisel to get down to the last ply you can then use an 8” grinder with 24 grit disk to sand the rest away. Brute force!
Post by fallguy1000 » Wed Jun 13, 2018 10:25 pm
Inplement of destruction, but might be needed here.
DAYTRIP
Post by DAYTRIP » Thu Jun 14, 2018 11:01 am
Gliding the grinder is key. Digging it in ....not good
IpswichGrady
Post by IpswichGrady » Thu Jun 14, 2018 12:08 pm
Ok.... what’s the difference?
Post by Fuzz » Thu Jun 14, 2018 2:00 pm
Light touch, keep it close to flat, and move quickly. If you do not it will dig in before you know it.
DAYTRIP
Post by DAYTRIP » Thu Jun 14, 2018 2:33 pm
It will honestly make quick work out of it. You can see when you are getting to the glass. Honestly you can’t do anything catastrophic as you are redoing it anyway. I always use it on prep work like this. It will make mountains of dust!
When I say digging in I mean don’t put a lot of pressure on. Let the disk eat. Folks get impatient/tired of holding on to the tool and want instant progress. With a grinder that creates divits. Keep the tool moving and watch what is happening. Usually you can get the wood to a point that it is thin (1/32) and then simply run the chisel under it and off it comes. Explore a little.
IpswichGrady
Post by IpswichGrady » Fri Jun 15, 2018 8:19 am
I have taken the protection off of my 4" grinder and am using 40 grit disks. Can't find any coarser disks. Luckily my local tractor supply had a 5 pack of those 40grt DeWalt disks for $14.
I have managed to create my own technique. It's working... just dusty work
Im a week behind my week ago schedule. Hopefully I will be able to get a lot done this weekend. '
IpswichGrady
Post by IpswichGrady » Fri Jun 15, 2018 8:21 am
I have a resin question.... When putting down a layer of resin, if it cures 100% before the next layer is applied why do you need to sand it smooth? I mean, if it is in a area that is not seen does it really matter? or does it have something to do with bonding principles?
