1995 Steiger Craft Restoration
Re: 1995 Steiger Craft Restoration
Post by fallguy1000 » Wed May 15, 2019 2:30 am
And the reason for staggering is to avoid hard spots. A hard spot creates a neighboring weak spot and stresses in hulls find those places to crack. This is why we don't end four or five layers of glass at 4" overlaps because you'd have a massive hardspot
garym
Post by garym » Wed May 15, 2019 8:00 am
Understood. Thx
Post by fallguy1000 » Wed May 15, 2019 8:39 am
Another reason for staggered lengths and no hard spots is fairing. Fairing over a hump takes a lot more material and is ultimately less fair. Of course this matters less than a weak spot/strong spot, but points out the sand through problem...
That transom might be a bugger to place as a single piece. You might need/want to build it in place. This can be done by clamping with bolts...iirc there is a tutorial here on it.
If there are seams due to size limits of the core; you can butt join, but must stagger joins.
Post by fallguy1000 » Wed May 15, 2019 8:47 am
Also add about 4-6 ounces for roller loss to your calc. A paint roller works well for transom wetout because you can load up a good bit of resin, but that is the downside. I use a squeegee to get resin back out for use on other things, but oftentimes, the rollers will be startimgnto cook.
Post by Fuzz » Wed May 15, 2019 5:17 pm
fallguy1000 wrote:
Wed May 15, 2019 2:26 am
No. Glass is layered largest first to avoid cut through when sanding.
I have been around a number of professional glass folks who stagger glass smallest to largest. As I said it is a matter of debate. If a NA were to give guide lines I would then go that way. In the end I am not sure it is going to matter all that much.
Post by fallguy1000 » Wed May 15, 2019 6:17 pm
You are too nice a guy for me to want to enter into a bunch of polemics. I'd rather meet you for some fishing in Alaska than worry about the order of things. However, another reason I like to do the biggest panel first is I am older and I get tired at the end.
There are guidelines, but fortunately, none of us are required to build to them.
Post by Fuzz » Wed May 15, 2019 6:46 pm
I feel the same way. Never want to be some sort of keyboard cowboy. :wink:
If you ever are able to get up this way I would be offended if you did not give me a chance to take you fishing :D
Users browsing this forum: No registered users and 42 guests
