Curacao CS 25
Larry B
Re: Curacao CS 25
Post by Larry B » Mon Feb 08, 2010 7:48 am
Looking good Peter, nice clean work :D This is a tough crowd to please but your doing a good job of it :wink:
Completed: FL14, OD18
TomW
Re: Curacao CS 25
Post by TomW » Thu Feb 11, 2010 1:16 pm
Hey Peter, Evinrude just announced a HO 15HP motor. Be perfect for you as a trolling motor. Lots of amps to keep the battery charged also. Only problem is it weighs 177 pounds vs 135 for the heaviest of the other 15HP motors. :doh: I think thats 81KG vs 61 KG.
Thought I'd give you a heads up. :D
C17ccx, Mirror Dinghy
Re: Curacao CS 25
Post by ks8 » Thu Feb 11, 2010 3:21 pm
Nice! :)
Yep... we need a good lookin' live (modestly clothed :roll: ) body in there for scale (no Photoshop allowed). :P
Did you epoxy down that access plate for the potable water?
peter-curacao
Re: Curacao CS 25
Post by peter-curacao » Thu Feb 11, 2010 7:46 pm
Tom thanks for remembering that! Image I really appreciate it, are there already some publications on the web about that Evinrude motor?
KS8 I taped the plate frame and pushed it in the thickened epoxy that way I get a tight fit and the wood is also sufficient covered with epoxy (under and sides of frame), when dry I took it out and took the tape of still have to screw it down.
Well seems I'm creating a battle tank she becomes stiffer and stiffer, I wonder how she is when the frames and that stiffener pipe and/or shelf is in, like a rock I guess. 8)
Finished glassing the sides and double taped the sole to the sides at that point (sole level) there are six layers of glass and a fillet 8O
Grinded down a putty knife to create a somewhat beefier fillet as normal not to make it stronger but just because I think at sole level it looks nicer, normal I use the black mixing sticks
Re: Curacao CS 25
Post by Cracker Larry » Thu Feb 11, 2010 7:53 pm
Looks great Peter. I know you are glad that's over with 8) The sole is a milestone for certain. Yep. she'll be solid as a rock :D
TomW
Re: Curacao CS 25
Post by TomW » Thu Feb 11, 2010 11:42 pm
Peter it's on Evinrude's site. It was on the home page when I went to there site today, down in the lower left. If it's not there it's in the High Output section of the engines.
icelikkilinc
Re: Curacao CS 25
Post by icelikkilinc » Fri Feb 12, 2010 7:16 am
peter-curacao wrote: Grinded down a putty knife to create a somewhat beefier fillet as normal not to make it stronger but just because I think at sole level it looks nicer, normal I use the black mixing sticks
Same line of thinking Peter, that is what I used in my TW28.. in most areas where I felt more comfortable at fillets with it...
Ilker
macs
Re: Curacao CS 25
Post by macs » Fri Feb 12, 2010 7:19 am
Good job Peter. I know It's a great feeling to have the sole in place.
Macs :D
peter-curacao
Re: Curacao CS 25
Post by peter-curacao » Fri Feb 12, 2010 5:29 pm
Image Image This feels weird!! Image Image
Re: Curacao CS 25
Post by Cracker Larry » Fri Feb 12, 2010 5:31 pm
A bold move indeed :!: 8)
Users browsing this forum: Google [Bot] and 53 guests
