PH18 Build in North Dallas (PH20)
flyfishingmonk
Re: PH18 Build in North Dallas (PH20)
Post by flyfishingmonk » Fri Jun 21, 2019 10:22 am
OrangeQuest wrote:
Fri Jun 21, 2019 10:17 am
Casey your boat is looking really great!!
Keep reading about all the motors and you may wind up with something over 200hp!! :lol:
Thanks!
Before I know it I will have three mounted on the end of this thing! 900hp!
Casey
Do not withhold good from those to whom it is due, when it is in your power to act. PR 3:27
Build Photos at Fly Fishing Monk's Phantom 18
Work Bio at Provision Retirement
flyfishingmonk
Post by flyfishingmonk » Sat Jun 22, 2019 11:04 am
Continued work on the panels that hide the fuel tanks. I am drilling holes that are for screwing down the panels to the stringers and a couple other blocks in the corners.
Last edited by flyfishingmonk on Sat Jun 22, 2019 12:05 pm, edited 1 time in total.
Dougster
Post by Dougster » Sat Jun 22, 2019 11:11 am
Dang, that flexi thing on your drill! My life is incomplete until I get one. I got tool envy. Nice build, I hope to see it some day at the Port A boat show in April.
Dougster
flyfishingmonk
Post by flyfishingmonk » Sat Jun 22, 2019 12:11 pm
Dougster
Thanks Dougster! That would be great if I could be done by April 2020. But maybe April 2021.
The flex extension I picked this up years ago and the part that holds the drill bit I got at Rockler. It came in a set with 6 or 7 different sizes to hold various drill bits.
flyfishingmonk
Post by flyfishingmonk » Sat Jun 22, 2019 3:46 pm
Can you guys think of a situation where going up to the 150hp would be an issue? I overbuilt the transom with three 1/2 sheets and 4 layers of biaxel, and two stringers in the middle coming all the way up to the deck. The floor added even additional glass and support. I could probably go up to 300hp to be honest, the way it is built. I dont have any concern but was curious.
Casey
Post by Fuzz » Sun Jun 23, 2019 2:29 am
I hear Merc will have a 450 out soon. Might be just the ticket :D
flyfishingmonk
Post by flyfishingmonk » Sun Jun 23, 2019 3:36 am
Or the Seven 627hp. :D
Casey
Aripeka Angler
Post by Aripeka Angler » Sun Jun 23, 2019 8:00 am
Casey
Sounds like you built the hull is plenty strong enough for 150hp.
I probably wouldn’t do it though.
If something bad happens it could torment you for a long time.
Richard
Completed boats...XF20 "Red Alert", Aripeka Angler's Strip Canoe, FS18 “Bare Bones”, GF12
Currently building...PY12 Kayak
Post by cape man » Sun Jun 23, 2019 11:23 am
I'm with Richard. That boat will scream with a 90hp, you'll get much better fuel efficiency, and you won't have to worry about the transom, gunwales, or stringers coming loose. Plus you will sit higher at rest or when idling. You are building her fat already, which is fine, but a 150 is kinda big for her.
However, she's yours, and a 150 would be fun! :help:
cvincent
Post by cvincent » Mon Jun 24, 2019 10:48 am
The new G2 115 and 150 will share the same block and weight. Depending on the price difference it may be worth getting the 150 and operating the boat conservatively.
Completed D15, Building PH18
Users browsing this forum: Jwhitakeriii and 1 guest
