Ilker's TW28
TheBroomside
Re: Ilker's TW28
Post by TheBroomside » Sun Aug 09, 2009 1:26 am
Ilker,
Fantastic progress.
What material did you use for the foredeck?
We didn't stop, but are not flying like you. Will post some pictures next week.
Peter
LUS
icelikkilinc
Re: Ilker's TW28
Post by icelikkilinc » Sun Aug 09, 2009 7:14 am
Hej Peter,
To get the shape I have used 2 6mm ply layers.. Installed the first one on the wooden karkas that is hidden inside, epoxy glued that to the hull. Than put the second layer of 6 mm op top of that and connected them with epoxy glue and temporary screws to hold in place until the epoxy cured. After that the screws being removed, holes filled and seams are biaxed and than the complete foredeck is covered with fiberglass. Than a little sanding action and than in the pic as you see, it is faired with epoxy fair. The pic is actually after the first layer of fairing and sanding so it was not that bad.. All the experience that I have now from the hull fiberglassing is paying off... I made so many mistakes at the beginning which meant lots of fairing but it is all gone now.. I will need a second thin layer and most probably a very thin 3rd layer there for a smooth paint job but I will do them later as I am about to receive the shaft and propeller tomorrow or tuesday so I want to concentrate on installing them and the other bits as tanks and wiring and plumbing below sole...
Ilker
icelikkilinc
Re: Ilker's TW28
Post by icelikkilinc » Wed Aug 12, 2009 4:26 pm
Shaft system, propeller, propeller protection and the SS rudder blade all in the shop now...
First set of tryouts, hopefully more tomorrow... At the end of the day I managed get everthing in place but no battery left to photo...
Ilker
TW28RJ
Re: Ilker's TW28
Post by TW28RJ » Thu Aug 13, 2009 9:06 am
Hello Ilker,
I've been quitely following your progress on the TW28.. it's looking very good. If you have a drawing of the rudder shoe, or as I believe you refered to it "propeller protection", would you post it. Short of a drawing more pictures. I've looked at several and have drawn up one of two, but I'm most impressed with what I see you have done with yours!
Ron
icelikkilinc
Re: Ilker's TW28
Post by icelikkilinc » Thu Aug 13, 2009 3:05 pm
Hello Ron
I had my personal sketches and I hope these below help
if you cannot understand from these pls ask speficly and I will try to help
Ilker
Ilker
TW28RJ
Re: Ilker's TW28
Post by TW28RJ » Mon Aug 17, 2009 8:39 am
Thanks Ilker!
icelikkilinc
Re: Ilker's TW28
Post by icelikkilinc » Sat Sep 12, 2009 5:22 pm
Well it looks as I am about to finish the boat below sole..
Tanks, plumbing and wiring is about to be complete.. Lots of material goes into the boat I gotta say..
Also started the engine for the first time and trying to upload a small clip of it for some diesel noise :D
Ilker
Knottybuoyz
Re: Ilker's TW28
Post by Knottybuoyz » Sat Sep 12, 2009 6:30 pm
Very very nice Ilker. I'm glued this thread and studying every move you make. :D
I just finished my last "Honeydo" and now I can start mine in the spring. Good luck, keep going and keep us posted.
Yours Aye! Rick
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it, cried beside it and then threatened to haul the POS outside and burn it!"
icelikkilinc
Re: Ilker's TW28
Post by icelikkilinc » Sat Sep 12, 2009 6:34 pm
Press Watch Motor Test link to watch the little sample clip...
Image Watch "Motor test"
Ilker
peter-curacao
Re: Ilker's TW28
Post by peter-curacao » Sat Sep 12, 2009 6:43 pm
Nice !! not that I know anything about motors but to me she sounds great! 8)
