modifications to gf 16 new build
Prarie Dog
Re: modifications to gf 16 new build
Post by Prarie Dog » Mon Feb 27, 2012 7:46 pm
Does anyone know what is an acceptable amount of variation on the flat part of a GF? We just used a two gallon kit of fairing material to flatten the back of T's GF. :oops: But it's really flat, much better than the "Popping Cork". I did what Larry says to do, screwed the back of the hull down to the build table, not tight just snug, supported the bow (Transom :D ) then glassed the inside and installed the tunnel. I think where we kinda lost the bubble is failing to trim the frames enough which forced the sides out causing the bottom to be low in the middle, also had a bump in front of the tunnel. If we build ten of these we might get it figured out. Having said all that the GF18 performs very well, so I don't think it's all that critical.
Post by Cracker Larry » Mon Feb 27, 2012 8:25 pm
I would say the rear 6'-8' on a GF16. The part that's in the water needs to be flat.
levicitus
Post by levicitus » Fri Mar 02, 2012 7:19 pm
Thanks again for all the help. I haven't posted for a while. I'm ready to run stringers for the sole and have a couple questions.
I'm using yellow pine 1x
1. Should be placed over the runners a@ 16" apart
2. Given that I will run cross members to the stringers port to starboard at 1' intervals. Will 1/4" sole material be sufficient?
I will cover with 6oz. Thanks ahead of time. happiness is an occupied jig.
levicitus
Post by levicitus » Sat Mar 03, 2012 8:44 am
Tried for two hours to post pics last nite. Seems my phone camera is too good to be compatible with the website software as the pics are distorted when reduced enough to fit the format. Any ideas?
Cracker Larry. How did you post the above pics? Wern't the pics from that particular thread lost? The way you just did that is the way I wand to use the forum. Post the pic and explain or question related to the pic. Am I making sense? thanks
Post by Cracker Larry » Sat Mar 03, 2012 10:57 am
Yes, all the pics in my GF16 and OD18 build galleries were deleted, but they are still on my computer :D I just uploaded it again. I've still got them all if you need to see anything specific.
Smart phones have a weird pic format, like the new flat screen TVs. It sounds like you have re-sized them to 640X480, which is causing the distortion. I use photoshop and I tell it to maintain proportions when I re-size. Always make the widest dimension 640 pixels, the narrow dimension ends up at 361 pixels, which maintains the proportions.
The pic above was taken with an older camera that used the traditional format. The pic below is from a DroidX, notice the difference in dimensions
That sounds about right, it would divide the space into 3 equal sections. Since a sole isn't specified for the GF16, you are sort of on your own. Check out T's GF12 thread for some sole ideas too.
1 foot intervals would be closer than necessary, 2' would be plenty. I think 1/4 is a little thin but you need to keep the weight down. If you fill the area between the bottom and sole with 2 part foam it will add a lot of extra support and 1/4 might be OK.
levicitus
Post by levicitus » Sun Mar 11, 2012 12:13 am
I need more epoxy and might as well order paint while I'm at it. I want to use the high build primer because I want as smooth a surface as I can get it but I'm painting camo pattern on the outside and a solid matching color inside. Top coat has to be flat and I want a paint that will be thin. Not like latex flat or duck boat paint. More like a quality smooth paint with 4 to 5 mil finish. Is this available in store or are there any ideas on where to get this? Thanks ahead. b happy
levicitus
Post by levicitus » Tue Mar 20, 2012 9:35 pm
Anyone have a good tip or two on mixing and applying graphite on the bottom?
PastorBob
Post by PastorBob » Wed Mar 21, 2012 5:02 pm
run your graphite through a strainer... Don't over do the graphite it will get clumpy.... Be prepared for lots of coats... USE EPOXY RATED rollers!!! Have tweezers ready to remove bugs...
... you thought epoxy was strong!
Romans 8:38-39
levicitus
Post by levicitus » Wed Mar 21, 2012 10:33 pm
PastorBob, Thanks for the help I especially enjoyed the comment bout da bugs. Think I have some paint strainers for the graphite. I'm on the last leg of the build and will post pics of the splash. Thanks for the help
levicitus
Post by levicitus » Wed Mar 21, 2012 10:37 pm
Are enamel paints epoxy compatible?
