FS17 Build
Re: FS 17 Build
Post by Cracker Larry » Mon Dec 07, 2015 8:29 am
I don't think that transom is mounted correctly- bottom of transom should line up with bottom of stringers. Looking good, though, nice and neat work.
I was going to say the same thing :doh:
remedy32
Re: FS 17 Build
Post by remedy32 » Mon Dec 07, 2015 9:01 am
Transom should be positioned against the angled cut of the stringback. Stringers butt against the transom flush with the bottom. The actual transom angle is controlled by 2 pieces (motor well sides) that run fore-aft between the transom and front of the motor well bulkhead. Take a careful look at the build notes and you'll see what we mean.
Wish my work was always as neat and clean as yours!
Bill
Parkrat
Re: FS 17 Build
Post by Parkrat » Mon Dec 07, 2015 9:22 am
I don't have the transom mounted yet. I just have it sitting up there to keep it out of the way. Garage is getting a little cramped! Don't worry.. I'm not going to deviate from the original design. :lol:
Haven't cut the motorwell sides.
remedy32
Re: FS 17 Build
Post by remedy32 » Mon Dec 07, 2015 4:09 pm
You see how much we care about our fellow builders 8)
Think the garage is crowded now....just wait a bit!
B
Parkrat
Re: FS 17 Build
Post by Parkrat » Mon Dec 07, 2015 4:55 pm
I do appreciate all the replies. I can be absentminded sometimes so the replies help. :lol:
I'm sure the garage will get worse. Once I get to the sanding part dust will be everywhere... not sure I can handle everything dusty. :| ..
Parkrat
Re: FS 17 Build
Post by Parkrat » Mon Dec 07, 2015 6:03 pm
I have a question. I measured out the bottom panel and towards to bow end it seems to dip in a little. I verified all my measurements several times. Does this look correct?
Re: FS 17 Build
Post by jacquesmm » Mon Dec 07, 2015 7:41 pm
Dont' cut, it does not look right.
Wait until tomorrow AM, I'll check in the office.
What is the offset (dimension) for that point?
Parkrat
Re: FS 17 Build
Post by Parkrat » Mon Dec 07, 2015 8:42 pm
1 1/2" and 16 3/4"
Thanks. Really appreciate it. I'll go out and measure everything again later, but that's the only odd spot.
Would it be wise to stack the plywood and cut 2 pieces at once?
Re: FS 17 Build
Post by Cracker Larry » Tue Dec 08, 2015 7:39 am
Absolutely. That will insure that both sides are identical, and both bottom panels. I always stack duplicate parts and cut as one. This way you only have to mark the layout lines on one panel also.
Re: FS 17 Build
Post by jacquesmm » Tue Dec 08, 2015 12:08 pm
Here is a picture of the panel drawing.
It does not look exactly like the plans because I rebuilt it to check.
Everything matches what you have.
As you can see, it is fair.
Could it be that you use additive dimensions like 1-1/2 PLUS 16-3/4?
That is not correct.
All dimensions are taken from the same baseline.
Using the same points, you first measure 1-1/2 form the edge of the plywood, mark the point and then measure 16-3/4 again form the edge of the plywood and mark the point.
Check your measurements and if necessary, fair the line. Fairness first.
Users browsing this forum: Dougster and 4 guests
