Bruce Crandall Flyer Hydroplane
danieloldhouse
Re: Bruce Crandall Flyer Hydroplane
Post by danieloldhouse » Thu Oct 20, 2016 3:02 pm
danieloldhouse wrote:Too much room around there, the other one was filling the whole space :roll: :D :D
LOL indeed this is a breeze, can fair the bottom also without any stairs 8)[/quote]
Yeah, but You can't pick up a tuna in there :doh:
Jokin' apart it's gonna be a beautiful boat :wink:
peter-curacao
Post by peter-curacao » Thu Oct 20, 2016 6:09 pm
peter-curacao wrote:LOL indeed this is a breeze, can fair the bottom also without any stairs 8)
That's very true but.......you can pick up other fish smelly wet things in a boat like that Image
peter-curacao
Post by peter-curacao » Thu Oct 20, 2016 6:31 pm
All frames are up, tried to draw the bow mold without all dimensions there, I think it's close enough to the drawing, as far as I can see all lines , water. chine and sheer are flowing towards it.
justin_dwyer
Post by justin_dwyer » Thu Oct 20, 2016 6:39 pm
Looking good Peter, will be an interesting build.
At the moment it looks like a whale skeleton like you'd see in a museum :lol:
danieloldhouse
Post by danieloldhouse » Fri Oct 21, 2016 3:34 pm
Didn't think about that Peter! I must fly down there when you'll finish 8)
peter-curacao
Post by peter-curacao » Fri Oct 21, 2016 5:39 pm
Figuring out the stringers in hardboard
Since I didn't got much reply on my stringer question, I decided to go ahead with 2x 6mm laminated 80 mm high full length inner stringers.
Maybe I will place outer stringers in 8 mm or also in 2x 6mm laminated.
peter-curacao
Post by peter-curacao » Sat Oct 22, 2016 10:49 pm
Figured out the stringers , well I think I did :doh:
glossieblack
Post by glossieblack » Sun Oct 23, 2016 12:48 am
Peter, I’ve had to learn my way through the choice maze for a 1:1 gearbox/transmission connecting an engine to a straight prop shaft for my ST21 build. As you may be seeking the same thing, the following may be of assistance. I should stress that what follows is self-evident to experts, but was a series of OMG revelations to an amateur like myself.
Firstly, when in forward motion, the propeller is trying to push the shaft through the boat, and the only thing stopping it is the gearbox/transmission. So the gearbox needs a thrust bearing strong enough to take the lateral and torsional loads. If it hasn’t, the geearbox or the engine’s crank shaft will quickly be destroyed. Marine gearboxes have appropriate thrust bearings, but most non marine ones do not. For example the ZF Hurth 45C marine gearbox that I’m using has one, but the snappy little 1:1 boxes produced for souped up go carts, and that I nearly used, do not. To use one, I would have had to insert a standalone thrust bearing between it and where the prop shaft entered the boat. If you choose to use an automotive engine with its’ own gearbox, or one of the hot go cart boxes, then you’ll need to insert a thrust bearing that is firmly attached to the hull itself.
Secondly, most marine boxes are designed to be bolted directly on an engine, either by using an off the shelf bell housing (and sometimes with off the shelf adapter plates as well), or by having a marine engine builder modifying an off the shelf bell house and/or adaptor plates. So for example, if you go with a common automotive or marine engine and ZF Hurth 45C combination, chances are there will be off the shelf bell houses and adapter plates available. If you use a non marine box, then you’ll need a length of shaft connecting the box to the thrust bearing, then another length of shaft connecting this to the prop. The shaft connecting box to the thrust bearing is likely to require a universal joint at both ends, to cope with the vibrating movement of the engine on its mounts.
Hope this is of some help. The stringers look the goods. :D
Post by cape man » Sun Oct 23, 2016 8:18 am
Moving quickly!
Post by Cracker Larry » Sun Oct 23, 2016 9:16 am
Looks great! And what Craig said, you are moving fast! Not building on island time :lol:
