Bruce Crandall Flyer Hydroplane
Re: Bruce Crandall Flyer Hydroplane
Post by TomW1 » Mon Feb 12, 2018 5:13 pm
As always Peter great work on the seats. I can't wait to see them in the finished boat.
Post by OrangeQuest » Mon Feb 12, 2018 5:22 pm
narfi wrote:
Mon Feb 12, 2018 5:09 pm
I love those seats.
You designed them or found plans somewhere?
I am wondering too?
They do look good. When you pad them will they be higher in the front on the bottom? Something to stop one from sliding forward?
Post by Jaysen » Mon Feb 12, 2018 7:44 pm
One piece kerfed ply back or multiple pieces?
poleposition
Post by poleposition » Mon Feb 12, 2018 8:56 pm
Jeff wrote:
Mon Feb 12, 2018 4:56 pm
Peter, the seats look nice and with black leather they will look great!! Jeff
Why am I envisioning Ricardo Montalban / " fine Corinthian leather " phrase now?
glossieblack
Post by glossieblack » Tue Feb 13, 2018 2:28 am
Very nice! :D
Post by cape man » Tue Feb 13, 2018 7:18 am
Yes Peter! Yes!
reefie
Post by reefie » Tue Feb 13, 2018 7:40 am
Great job on the seats Peter! They will look fantastic after upholstering.
I may have missed something, but do the central planks eventually get cut out of the cockpit area?
"If you want something you have never had, then you've got to do something you've never done"
Post by pee wee » Tue Feb 13, 2018 9:38 am
Here's the link to the plans: http://boatplans-online.com/plans/BPO_flyer.pdf
I see a big set of hatches for engine access, I was wondering how that was going to go.
Looking good, Peter!
peter-curacao
Post by peter-curacao » Tue Feb 13, 2018 10:26 am
As always thx for the nice reply's guys 8)
I love those seats.
No plans, I just build them along the way, I start drawing the base with a 40 cm X 40 cm square changed it to 50 cm front and 40 in the back, then measured around the radius corners at the back which gave me a 60 x 60 cm square after trimming the excess at the base because of angling the backrest I ended up with 56 cm high backrest and trimmed it at the top to my liking's (the curves), then I decided to make some triangles for the sides of the seats cause I think that looked better as a straight backrest (look closely and you see them)
At top in between the seats I'm thinking to make a filler piece towards the back frame in same color, which will receive a logo or pin striping sort of what you see in a Vette
Jayson hopefully explanation above will explain, so it's 4 pieces base, backrest and two side triangles.
That's the plan, or maybe I form the foam to to my / a butt (same as I did with the little fighting chair I made) it depends on what the upholstery guy says.
Yes they will be cut out together with the decking planks, reason I glassed and faired them is because I want to try and save the cut out to make it in to a lid for storage, so cockpit will be protected from the elements and vermin during storage and trailering.
During decking I will glue in four vertical frames supporting the SS piano hinges, I want the hinges to be in between a deck seem, I can measure it but this way is just a safer way to play.
Post by Jaysen » Tue Feb 13, 2018 11:00 am
Peter-C, explained perfectly.
Now get back to work!
:P
Users browsing this forum: fallguy1000 and 1 guest
