Woods Skoota 32DM
Re: Woods Skoota 32DM
Post by fallguy1000 » Wed Mar 25, 2020 12:30 pm
Helm is awful heavy. Am I going to boat builder hell for it?
20 lbs..shudda cudda wudda used a lighter core
Gonna build on.
MikeyGnz
Post by MikeyGnz » Wed Mar 25, 2020 9:27 pm
Gonna build on.
One day in rough seas using the wheel to stay upright and steer you'll appreciate the extra strength that usually comes with extra weight.
Post by fallguy1000 » Wed Mar 25, 2020 11:00 pm
I just realized I can use 17 oz glass on the roof and save 140 ounces and a LOT of work. Roof might be a bit weaker, but we don't need to walk up there much.
Post by fallguy1000 » Mon Mar 30, 2020 7:00 pm
Glassed the rooftop today with 17 oz.
It is about 10.4 yards of glass. 177 ounces glass
Had to do a real wet layup to get the scrim lines filled.
96,96,36,12 oz. 240 oz resin
Used about 12 oz fillers on the tapes which were applied this weekend.
Working alone...pretty big job. Feel like a ply boat builder glassing a hull.
Post by Fuzz » Mon Mar 30, 2020 7:49 pm
How did that epoxy use compare to your normal way of doing things given the waste rate?
Post by fallguy1000 » Mon Mar 30, 2020 8:04 pm
Well, I had 27x133 scrim holes and holes in some of the core. I used a feeler gauge and decided the holes needed about .010" of epoxy each and calculated a need of 106 ounces per panel or 212 total, but I kinda figured I might need to go a little heavier as this is a tricky work back out of it wetout. (A bit wet it is!)
There was no waste here as this was all hand laid.
To be honest, I chucked about 4 - 6 oz epoxy because I overmixed my top it off at the end.
One spot was a little airy and I added some resin at the end. You can see it on the back left side.
Post by fallguy1000 » Wed Apr 01, 2020 3:38 pm
The Holy Grail!
Post by Jeff » Wed Apr 01, 2020 3:47 pm
What are you doing FallGuy??? Just looking at room?? Jeff
Post by fallguy1000 » Wed Apr 01, 2020 4:18 pm
Nope. Placing head walls😊for real. Or, yes, doing dryfits.
Post by fallguy1000 » Wed Apr 01, 2020 4:19 pm
That there is an $800 shitter with a $200 flush control.
Too bad it doesn't have a paperless mode.
Users browsing this forum: Bogieman, Netpackrat and 6 guests
