FS14 Wolf's build
peter-curacao
Re: FS14 Wolf's build
Post by peter-curacao » Sun Oct 15, 2017 9:43 am
Sun Oct 15, 2017 9:25 am
Internal Combustion Engine
Aha I thought it was something like that I just couldn't name it, thank you 8)
Post by Jeff » Sun Oct 15, 2017 11:45 am
Nice work Capt UB!!!! And fast!! Jeff
Post by Capt UB » Sun Oct 15, 2017 12:45 pm
My bad.... I thought it was a type-o!
Post by Capt UB » Sun Oct 15, 2017 5:24 pm
Adding photos on another cpu later, to my gallery. Can't do it from this cell.
Starting one thing at a time... 363 days till the next meet up!
Re: FS14 Transom clamp boards
Post by Capt UB » Sun Oct 15, 2017 9:00 pm
Looks like I will just get by without a jackplate.
The transom is 20" +, ob is 18" from clamp to cav plate.
That does rise the ob by 2" which is good. Just need a little more setack. Could I put the camp boards on the outside of the transom for a bit more setback? I would do this after the transom has been glassed. I do not want to cut down the transom, I maybe getting a long shaft 15 2 stroke in the future. There will be a aluminum camping plate inside. Ob's will be bolted on.
If I have to, I made a jackplate 3" setback 2 up and 2 down I could use.
Just dreaming now... Long ways till I need to really think about any of this...
Re: FS14 What wood to use for cleats
Post by Capt UB » Mon Oct 16, 2017 5:57 am
What wood for cleats should I use, buying at Home Depot.
Post by cape man » Mon Oct 16, 2017 6:12 am
I used 1x2 pine.
Post by Capt UB » Mon Oct 16, 2017 9:23 am
I used 1x2 pine.
1x2 pine it is.
Thanks, Bob.
Re: FS14 Puzzle joint glue up and tape
Post by Capt UB » Mon Oct 16, 2017 10:00 am
FS14
I have the CnC kit.
Would I need to run glass tape on both sides of the puzzle joint, before assembling? Found the puzzle joint info, but did not see if I tape first or during the the taping of the hull.
Thanks, Bob.
Post by jacquesmm » Mon Oct 16, 2017 10:26 am
No.
No tape.
