FS14 Wolf's build
Re: FS14 Wolf's build
Post by Capt UB » Wed Oct 31, 2018 7:41 am
thb wrote:
Wed Oct 31, 2018 6:56 am
Bob,
I am not sure I interpreted your posting correctly. Is that picture of the motor after you already lowered it 2 inches?
What is with those funky cap screws?
Regards
:lol: :lol:
Just the hold down backing plate removed. Cutting down 2" tonight. Two inches will be at the bottom of the hull. So all will be good. Tom (TomW1) was right about using the smaller pitch 7.5. I too close to the transom to be that high off the hull bottom also. Going back to basics!!
As for my "funky cap screws", they are allen head and the other is the thru bolts (already removed) everybody should have on! I have never liked the lockdown bolts OB's come with.
Post by OrangeQuest » Wed Oct 31, 2018 8:18 am
I remember Capt UB you posting about not liking the OB bolts they come with. You may want to see if you can get something in the same metal as the OEM bolts if you are concerned with the bolts rusting.
I am very confused about your posting on your tiny tach not working :doh:
You are getting a reading just not correct RPMs? It doesn't read anymore?
Your first run with the tach worked! just seemed to be off by half. The tach measures time between spark pulses. At 360 and wrapped around one wire. If the tach is programmed to see a pulse every 1 second then it knows that is XXX rpms. but if it is seeing that pulse every 2 seconds then it thinks it is half the RPMs. You need to program the tach to a longer delay between pulses and go back to wrapping it around one wire only.
With you stating that the motor is sitting to high I am guessing the prop is venting and causing the motor to reach max rpm. That is why you were getting 3000 RPM, half of max. You also stated you have been around outboards enough so you should know if your motor is idling to high or to low.
Post by Capt UB » Wed Oct 31, 2018 9:42 am
The bolts are steel from the factory.... The allen head bolts work great. Most thieves don't carry big allens with them, but vice grips will work but so much is in the way, it takes time!!!
The none of the TinyTach systems work on this type of spark system, they have not kept up with the new OB systems. Going to buy a Tohatsu made one for $ 100 and use the TT on my new 2018 lawn tractor, which has an old school engine!
I'm talking about height and setback, when talking about the OB being to close to the transom and too high. This has to do with the water leaving the bottom of the hull and rising up. This is a subject for another time.
As for knowing what an OB sounds like at a idle or WOT, depends on so many things; manufacturer, 2 stroke, 4 stroke, old ears, old motor, new motor..... Tohatsu are (I Think) nosier then Yamahas..... My 2003 Yamaha 60 4 stroke was so quite, I sometimes tried to start it when it was already running!!
Post by OrangeQuest » Wed Oct 31, 2018 10:27 am
OooooH! kay! :D
txjm
Post by txjm » Wed Oct 31, 2018 5:52 pm
"The none of the TinyTach systems work on this type of spark system, they have not kept up with the new OB systems. Going to buy a Tohatsu made one for $ 100 and use the TT on my new 2018 lawn tractor, which has an old school engine!"
The link below is the tach I used. I was successful in using it on a 5hp Merc 2 stroke, 18hp Tohatsu 2 stroke and a 20hp Tohatsu 4 stroke. One setting change.
https://www.hardlineproducts.com/produc ... ach-meter/
Chip
Post by Capt UB » Wed Oct 31, 2018 6:36 pm
Will sand the cutout rounder and glass/epoxy.
Stearing clear and lifted up motor is clear.
Transom cut down 2.5".
Now it's just right!
The transom cutout pieces.
Post by Capt UB » Wed Oct 31, 2018 6:39 pm
Chip
Thanks Chip.
For a few more dollars, I can buy a Tohatsu tach, made for this motor!
Post by TomW1 » Wed Oct 31, 2018 6:44 pm
Bob looks like you have the ventilation plate even with the bottom. I agree buying a proper tach is not much more than buying a TT. Send the TT back for a refund.
Post by Capt UB » Wed Oct 31, 2018 6:49 pm
The TT is going on my new lawn tractor.
Post by TomW1 » Wed Oct 31, 2018 7:29 pm
Now that is a machine.! :D
Users browsing this forum: pedroe and 4 guests
