The Plytanic 2.0 - FS17 Build
silentneko
Post by silentneko » Thu May 17, 2018 9:57 pm
Lol, guys it's just a corn snake, he was released unharmed.
The insides not to bad, I'm working out a few issues, but hope to glass soon.
Post by topwater » Fri May 18, 2018 6:52 am
Dang I am glad I don't live where there are lots of sneaky biting things /
Fuzz you're kidding right :?: You just live where big assed bears run 35 mph and laugh at 44 mags :lol:
Post by Eric1 » Fri May 18, 2018 10:39 am
Congratulations on the flip!!! The boat is looking great! :D
Post by Jeff » Fri May 18, 2018 1:05 pm
Nice flip!! Jeff
silentneko
Post by silentneko » Tue May 22, 2018 8:51 pm
Started working on the interior. I hate having to crawl inside it right now, but it's the only way to reach the middle. I needed to use one strap to pull the hull in about 1/2" or so to meet the frame, other then that it seemed pretty fair to the rest.
I filleted all the seams a few nights ago.
3050
I then taped just the bow, because I wanted to try out some peel ply I have. It worked ok, but the weave is so open in the biaxial tape that it couldn't make it smooth. Also peel ply seems to work much better on outside edges, on the inside it slides around a lot.
3051
Today I cleaned up some fillets and then taped the inside seams.
3052
3053
I will hopefully try to get the inside glassed this week. Then I'll need to work on building the stringers.
Post by OrangeQuest » Tue May 22, 2018 10:07 pm
Looking good!
Post by Jeff » Wed May 23, 2018 7:09 am
Nice work and progress silentneko!! Jeff
silentneko
Post by silentneko » Sat May 26, 2018 3:22 pm
I sanded down the tape and rolled on a slurry coat to help fill in the weave prior to bottom glass. I had ambitious plans, but they didn't quite work out. I was going to glass then whole bottom, however it is much more difficult then the exterior and took more time then I expected. So I could only finish one half.
I laid out the glass then rolled up one side. As mentioned earlier this is really a 2 person job, so it didn't go as planned. The half I rolled up is pretty distorted now. I hope it can still be used, but the biaxial is harder to straighten out then woven. Here is the half I glassed yesterday.
3060
I took longer then expected to wet out, I was using a roller to push around resin then a glass roller to smooth it down which worked great, but is a little slow. I used some scrap pieces as fillers up front.
3061
I'll fill in the sides with 6oz woven after the floor is in. Good thing about the distortion is because it's under the sole no one will see it.
Post by Dougster » Sun May 27, 2018 9:27 am
I think the inside glassing is harder too, but that looks fine to me. Next is the other side and then Bob's your uncle! I don't even see any sign of bubbles or dry sections but the odd little bubble is easily dealt with.
silentneko
Post by silentneko » Sun May 27, 2018 10:09 am
There are only small air pockets where the rough weave hits, nothing that will bother anything. The next section will be the worst part as it's heavily distorted already, but I'll make it work.
