GT27 Build (Wes K)
wkisting
Re: GT27 Build (Wes K)
Post by wkisting » Sun Aug 11, 2019 11:33 am
And now there's a cockpit sole...
Wes
piperdown
Post by piperdown » Sun Aug 11, 2019 11:55 am
Looks great :D
Eric (aka, piperdown)
wkisting
Post by wkisting » Mon Aug 19, 2019 8:18 am
Ugh. After a short reprieve thanks to rain and a few cooler days, the dreaded heat is back and as relentless as ever. Progress has slowed again. All I managed to do this entire weekend was build and install the rim for the hatch that will cover the coffin box for the fuel tank.
Wes
Post by fallguy1000 » Mon Aug 19, 2019 8:21 am
Use your downtime to plan systems, wiring, all that..
Post by Jeff » Mon Aug 19, 2019 8:51 am
Wes, I could not agree more, between the heat and rain here in Florida, it is hard to get anything accomplished!!! Jeff
wkisting
Post by wkisting » Wed Nov 06, 2019 10:57 am
Well, we ended up taking a little over two months off because of the insufferable heat and some family vacation time, but we're just starting back to the build now that the cool Fall weather has arrived. It was nice to have a break after going at it steadily for the past year. Not much new to report, except that I've now installed the hatch rim and built the large hatch that covers the forward fuel tank compartment. It came out great! Just need to settle on an unobtrusive, secure, and simple way to hold it down. Since it doesn't have to be accessed often, I could screw it down with a small bead of sealant along the rim and the fastener holes, but I'm also considering a piano hinge along the forward edge with a pair of hasps at the aft edge. I built it like a griffiths hatch, so even if I don't use sealant, I don't think there's much chance water will be able to travel up over the hatch rim to get into the fuel compartment.
Wes
Post by Jeff » Wed Nov 06, 2019 11:52 am
Wes, welcome back!! Yes the heat has been incredible in Florida this year!! Still a high of 86 through this week!! Again, welcome back!! Jeff
wkisting
Post by wkisting » Sun Nov 10, 2019 6:50 pm
A few pictures of the recent progress...
I installed the hatch rim and built the hatch that covers the forward fuel compartment. The hatch is very big, but very solid (no flex) and not too heavy. I think this will work really well for keeping out water but allowing for easy inspection of the tank/fittings.
I also drilled ten 5/8" holes in the transom to prepare for mounting the transom bracket. This was nerve wracking, but with a good drill bit and an old drill guide to help me hold the drill perpendicular to the transom, all came out well.
Now that I can see from the interior where the bracket mounting holes are located, I can design the backing plates for the bolts and then finish the last bit of floor framing to create a slim well around the mounting areas for periodic access/inspection of the bolt heads. Then I can FINALLY fasten down the sole. It will be so great to get that done...
Wes
Post by Bogieman » Sun Nov 10, 2019 7:35 pm
Very nice!
Post by Jeff » Mon Nov 11, 2019 7:51 am
Nice progress Wes!!! Jeff
Users browsing this forum: smici01 and 4 guests
