Coach
- Frequent Poster
Post
by Coach » Mon May 27, 2019 3:58 pm
- Very Active Poster
Post
by BB Sig » Mon May 27, 2019 6:50 pm
How does it feel when you run your hand over the surface? Looks can be deceiving. Try closing your eyes and feeling for lows.
Coach
- Frequent Poster
Post
by Coach » Mon May 27, 2019 7:28 pm
Its smooth but not flat. You can feel the ripples of the weave and edges of the tape.
- * Bateau Builder *
Post
by narfi » Mon May 27, 2019 7:39 pm
Like BB Sig said, looks can be deceiving.
It is ok to sand through the cotton strings that hold the glass together, you just dont want to grind through the actual glass.
My guess from looking at your picture (again looks can be deceiving, so be careful) is that you could sand a little deeper than you have and still be ok.
Post
by Capt UB » Tue May 28, 2019 6:00 am
Coach, nobody told you about this part of boat building? This is the fun stuff, you go insane and build arm muscles....
She is still looking good. Sanding carefully will help at this point.
Coach
- Frequent Poster
Post
by Coach » Tue May 28, 2019 6:20 am
I thought you guys were joking!
I appreciate the feedback.
I will take the advice from you guys and make another pass with my RO sander. Might pick up some 60grit discs. I was blowing thru the 80s pretty quick.
I do think I can get the side panels and transom down a bit more and this will help me use less of the quick fair this coming weekend. This forum is great!
Aripeka Angler
- * Bateau Builder - Expert *
Post
by Aripeka Angler » Tue May 28, 2019 6:29 am
narfi wrote: ↑Mon May 27, 2019 7:39 pm
^^^ This is great advice. I’d sand some more with the long board before putting putting on quick fair.
Richard
Coach
- Frequent Poster
Post
by Coach » Sun Jun 02, 2019 11:09 am
I was able to put 8 hrs into fairing this weekend. I am 100X happier after using Quick Fair! I can work with this finish. What a difference. I am quite sure I didn't mix the BBC filler correctly but I certainly learned alot through the process. She is very smooth and flat now. I have a few spots I need to circle back on but she is looking good. The 3M Hand Longboard with 80 grit was definitely the way to go although my shoulders might complain. Next week I am hoping to get the Skeg on and start laminating the rub rail with my leftover 7mm okoume.
My plan is to laminate three layers of 7mm strips about 2" or 2.5" wide. Painted and then use a rubber bumper rub rail, probably the ones sold at BBC. I wish I could see a sample of the rubber rub rail. Its hard to know how it will look with 3/4" thick wood rail with the rubber bumper. Any thoughts? If I dont use the rubber rail I would choose a hardwood rub rail and not laminate the okoume. Decisions, decisions!
After some research is seems I should roll on a light layer of neat epoxy over the Quick Fair before priming. My plan is to use System 3 Yacht Primer. Do you agree thats the right way to do it?
Here are some pics:
Post
by Dougster » Sun Jun 02, 2019 11:18 am
Sure looks good. I'd skip the neat epoxy and go straight to the S3 primer. That's what I've done and three builds. See what other folks say.
Post
by Capt UB » Sun Jun 02, 2019 2:47 pm
Coach wrote: ↑Sun Jun 02, 2019 11:09 am
I'm using .25" x 1.50" x 16" pine lattice, three layers for the rub rail base, then BBC's Tessilmare Radial 30. It is 1.25", the pine lattice is 1.50" wide, I'm going to bull nose the bottom edge just a bit. Should be lite weight looking and clean... Some boats have big rub rails, I like them smaller.
