C19 in Richmond, VA
joe2700
Re: C19
Post by joe2700 » Sun Sep 15, 2019 7:24 pm
fallguy1000 wrote:
Sat Sep 14, 2019 7:10 pm
Casters are less than ideal because you won't ever be level.
I find using casters then jacking it up and dropping it straight onto blocks when you need it level works well. I end up using my floor jack all the time with the boat to make adjustments and move around. Do make sure they are strong casters, the boat gets heavier and heavier if you keep using the same strongback as a cradle after flipping.
Dan_Smullen
Re: C19
Post by Dan_Smullen » Mon Sep 16, 2019 8:08 pm
I’ve thought about that, but for me, it has weighed out to be more of a benefit to be mobile in a tight work area. My intention is to set the frames level on the jig with a laser, while the jig is located in the position in which it will sit while epoxy is curing. But it will be essential for me to push it out of the way in between work sessions.
My wife isn’t going to abide a boat in various stages of construction obstructing her path to the driveway for too long.
I like the idea of leveling feet that I can move up and down as needed.
Dan_Smullen
Re: C19
Post by Dan_Smullen » Mon Sep 23, 2019 8:57 am
This seems like another worthwhile milestone. Jig assembled.5482
At 43” wide, my jig is much wider than any recommended size, but this was intentional, to aid in assembly. I had the notion that I would make the jig width match the stringer spacing. In hindsight, any benefit was minimal.
On each temporary frame, I routed a bottom of sole reference line, and cut the vertical supports to be the 40-3/16” baseline to sole dimension, plus the width of the 7-1/2” for the width of the jig rails. I aligned the top of the support with the bottom of sole line, and clamped it tight at 20” off center to align with the inside of the jig. Flipped over the frames with supports clamped to it, and screwed from the face. 5475
On the jig, I marked locations of the frames, and then offset for my gussets, which when installed squarely in a precise location, provided a hard stop against which vertical supports could be indexed, and clamped in place.
5477
5478
5479
I then used a story stick to check bottom of sole dimension from top of jig, which represents the baseline.
5480
It was a simple system, but I didn’t have an appreciation for how high this assembly would place the keel line. If I don’t lower all of this somehow, working on the bottom panels is going to be challenging. Not sure what will be a greater challenge, glassing and fairing something high, or lowering the entire assembly.
5481
Big thanks to Jacques for taking the time to correspond with me about adding flair to the bow. I have to take some time this week to dig into his notes, but I feel like he has blessed the plan, and it is in motion!
5483
This week is install motor well sides, and laminate and install transom.
Dan_Smullen
Re: C19
Post by Dan_Smullen » Mon Sep 23, 2019 11:28 am
Regarding clamping board, will either sapele mahogany or white oak be suitable materials? I have enough of either to work with.
Thanks,
piperdown
Re: C19
Post by piperdown » Mon Sep 23, 2019 2:29 pm
Thanks,
Clamping board like on the transom?
Eric (aka, piperdown)
Dan_Smullen
Re: C19
Post by Dan_Smullen » Mon Sep 23, 2019 3:23 pm
Thanks,
Yes. Exactly.
Re: C19
Post by narfi » Mon Sep 23, 2019 3:47 pm
hehe, looking good, but the fisheye camera lens makes that the most bowed looking strong-back I have ever seen :P
piperdown
Re: C19
Post by piperdown » Mon Sep 23, 2019 4:17 pm
Thanks,
Yes. Exactly.
I don't have the plans for the C19 but I guess I'm a bit surprised that it has a clamping board instead of multiple layers of ply bonded together to make the appropriate thickness.
Ask Jeff or Reid about the white oak. I've heard (never used/experimented) that white oak didn't bond well with epoxy but that might be from older epoxies. https://www.epoxyworks.com/index.php/epoxy-with-oak/
Dan_Smullen
Re: C19 in Richmond, VA
Post by Dan_Smullen » Sat Oct 05, 2019 6:21 pm
After what felt like a nearly catastrophic transom lamination, I re-thought my Gel Magic game and whipped up some notched spreaders on some lexan. 8'x10" hobby sheet from the big box yielded 2, which worked like a charm. I also learned to mix the goo on a larger sheet with a plastic putty knife. Combined with the spreader, some tips from ya'll, the application on these stringers was worry free!
5615
I also DIY'ed some puzzle joints on the stringers. Had the notion of a calm glue up, first "scarfing" two halves together, then laminating, but the cool temps today caused a batch of epoxy mixed this morning to cure slowly. I got tired of waiting, and with my new spreader attached the first inboard stringer. A cool head, a nice mixing board, the spreader, and some help flipping from my wife, made for an easy lamination. Also realized puzzle joints are not necessary on the stringers. The overlapping joints is where the strength comes from, but it was a good exercise before it's time to cut some hull panels, which hopefully, will not be too far into the future.
5617
I'm happy with the way all of the parts are fitting together. Everything seems straight. My intention is to hang the transom and clamping board off the end of the stringers. I was waiting to see the dimension between the bottom edge of the notch in the motor well sides and the notch in the stringer knee. I'll rip the clamping board to this dimension, minus a little for glue. Temporary attachment between stringers and transom for now.
5618
5619
5612
Just for fun, here's a pic of some work from the real job. What will be a decorative mirror grill for a house in Easton, MD.
5613
5614
changeat44
Post by changeat44 » Tue Oct 08, 2019 6:01 am
Hello Dan,
I follow your build, looks nice!
Did you make your flared bow in AutoCAD? Or will the result be something that will surprise you when it's done?
I'm also interested in a flared bow on my CX21, can't wait to see yours.
I've read somewhere on this forum it has been done before; are there any pictures, I can't find them?
Daniel
Users browsing this forum: No registered users and 5 guests
