Central FL OB15
Re: Central FL OB15
Post by Capt UB » Fri Nov 01, 2019 2:22 pm
The Chironex wrote:
Fri Nov 01, 2019 1:09 pm
Spent an hour or so today rounding edges and scuffing up epoxy. I’ll give it all a good sand with 100grit and then hose it off with the air compressor. About ready to start glassing.
I like to wipe down the hull first with water or alcohol (with a rag) to remove any blush or sweat before sanding or laying glass. One of the reasons I only use BBC's MarinEpoxy with the slow hardener, very little blush if any!!
The Chironex
Re: Central FL OB15
Post by The Chironex » Mon Nov 04, 2019 11:09 am
Got out in the garage and started rolling out the tape yesterday. Didn’t get a chance to apply any epoxy but it’s ready to go. Hopefully I can get rid of this kink in my neck so I can get this show on the road.
Reid
Re: Central FL OB15
Post by Reid » Mon Nov 04, 2019 11:18 am
Looks like it will be a nice clean tape job. Don't forget to pre-wet your wood before tape or any fiberglass goes down.
-Reid
- Steven Wright
The Chironex
Re: Central FL OB15
Post by The Chironex » Mon Nov 04, 2019 12:12 pm
-Reid
Yeah I tried to make it easy on myself and lay it all out dry and make all my relief/fold cuts. I’ll roll them all back up and label them with some painters tape so they’ll be ready. Hehe I’ll be sure to pre wet :lol:
Reid
Re: Central FL OB15
Post by Reid » Mon Nov 04, 2019 1:41 pm
I figured that's what you were doing, I do the same thing.
-Reid
- Steven Wright
Re: Central FL OB15
Post by Dougster » Tue Nov 05, 2019 10:08 am
I've had trouble with the tape sticking and pulling threads of glass off. Am I using the wrong kind of tape :doh:
The Chironex
Re: Central FL OB15
Post by The Chironex » Tue Nov 05, 2019 3:21 pm
Yeah painters tape seems to work the best. Still pulls fibers but if you hold them together as you peel it, it won’t pull most of them.
Re: Central FL OB15
Post by Capt UB » Tue Nov 05, 2019 6:54 pm
I marked the fiberglass tape with a sharpie. Really helped me lay the tape down.
Question for you,
is it only one layer of tape on the keel?
The Chironex
Re: Central FL OB15
Post by The Chironex » Tue Nov 05, 2019 8:19 pm
Question for you,
Yeah I questioned that as well. 1 outside on the keel and 2 inside based off the lamination schedule.
Re: Central FL OB15
Post by Jeff » Wed Nov 06, 2019 8:15 am
Guys, lets ask Jacques!! I am confident you will have an answer today. Jeff
