Cat 12 In Sao Sebastiao - SP - Brazil
rebello
Post by rebello » Thu Jan 05, 2017 4:48 pm
Dear friends i just started building the Cat 12.
Wood cut to shape, hull sides and frames assembled, ready to turn and bottom panels.
Life is Good
Rebello
Re: Cat 12 In Sao Sebastiao - SP - Brazil
Post by Jeff » Thu Jan 05, 2017 4:54 pm
rebello, good start!! Keep the photos coming!! Jeff
rebello
Post by rebello » Fri Jan 06, 2017 1:21 pm
I was wondering if would be possible to build this boat in foam sandwich as well, would it affect the balance of the boat?
Life is Good
Rebello
Post by jacquesmm » Fri Jan 06, 2017 1:38 pm
rebello wrote:I was wondering if would be possible to build this boat in foam sandwich as well, would it affect the balance of the boat?
Yes it is possible but:
- it will not be much lighter
- it will cost 2 or 3 times more: more glass, more resin and good marine foam cost more than plywood.
rebello
Post by rebello » Fri Jan 06, 2017 9:33 pm
Thanks Jacques
Life is Good
Rebello
csotelo
Post by csotelo » Fri Jan 06, 2017 10:18 pm
Nice boat. Good to see someone else building in Brazil.
I'm building FS14_LS in Sorocaba-SP.
If you need anything from São Paulo, just contact me.
Regards,
Carlos.
rebello
Post by rebello » Sat Jan 07, 2017 6:17 am
thanks csotelo very kind
Life is Good
Rebello
rebello
Post by rebello » Sat Jan 07, 2017 6:20 am
Jacques, could i use 4mm depron for the sides and bottom and 25mm or 50mm for the frames and transom? Just wondering again.
Life is Good
Rebello
gbellodi
Post by gbellodi » Thu Feb 02, 2017 6:30 pm
Nice job!
What kind of plywood are you using? Any idea about its density? Is your supplier from São Paulo?
I'm planning to build a sailboat in Jaboticabal/SP city but I have no marine plywood suppliers around.
Good to know that others are also building boats here in Brazil.
Um abraço
Post by jacquesmm » Thu Feb 02, 2017 6:38 pm
Depron is polystyrene. Probably not but I never tested it.
Get a sample, skin it with epoxy and glass and test in bending. Let us know.
