AD16 Myrtle Beach
Re: AD16 Myrtle Beach
Post by Bogieman » Sun Sep 08, 2019 4:36 pm
OrangeQuest wrote:
Sun Sep 08, 2019 3:59 pm
Capt UB wrote:
Sun Sep 08, 2019 12:18 pm
Netting on the scuppers?? :doh:
On a lot of sailboats, the transom scuppers are very large or open transom, a filled or slow draining cockpit can be a very dangerous. Winch handles and other things tend to get washed overboard. A net can stop the item and still drain quickly.
Makes sense. On all my anchor lockers I am putting in silicon sink strainers before the drain chases. All the grass, mud and sea creatures will be strained out before going into the drain tube.
[/quote]
I'm going to double the size of the scuppers. I was worried about stuff getting in (because some of my time will be in the Waccamaw where there's snakes) but a following wave is a bigger concern
Post by Bogieman » Sun Sep 08, 2019 4:38 pm
I obviously don't have full grasp on the cut and paste function
Post by OrangeQuest » Sun Sep 08, 2019 8:04 pm
You could always add custom flappers like SkinnyDip has!
Post by Bogieman » Tue Sep 10, 2019 5:01 pm
Today I installed the skeg with two layers of FG tape, fared and shaped the center board ( it’s ready for fiberglass cloth now ), enlarged the scuppers and did more sanding on the hull
Post by OrangeQuest » Tue Sep 10, 2019 5:17 pm
Everything looks great! What is the last picture of? The round white hole?
Post by Bogieman » Tue Sep 10, 2019 5:32 pm
Thanks, OQ! The last pic is the pivot end of the centerboard. The plans called for an optional (but recommended ) delrin ring so the pivot pin doesn't bare directly against the wood of the centerboard. I went with the 1 1/4" PVC instead. I was too wore out (or lazy) to label everything :D
Post by terrulian » Tue Sep 10, 2019 6:32 pm
Great stuff, keep it coming!
Post by Jaysen » Tue Sep 10, 2019 7:00 pm
I feel like you need to find some sanding to do...
Post by Bogieman » Tue Sep 10, 2019 7:33 pm
Thnks, Tony!
Post by Bogieman » Tue Sep 10, 2019 7:38 pm
Pretty sure I'm maxing out my production rate. At least that's what my body tells me :D The nice thing is that every job I'm accomplishing at this point sort of feels like knocking out a bunch of little punch list projects. Allows me to work on multiple things at the same time.
