AD16 Myrtle Beach
Re: AD16 Myrtle Beach
Post by Bogieman » Thu Apr 02, 2020 8:28 pm
Been working on rudder and tiller assembly. Need one more pintle and gudgeon at the bottom. I will attach it to the skeg because I don’t want to drill into a water tight portion of the boat . Had to dig a hole in Oder for the rudder to fit without lifting the boat.
Post by terrulian » Thu Apr 02, 2020 8:36 pm
How are you planning to attach the gudgeon to the skeg?
Post by Bogieman » Thu Apr 02, 2020 10:48 pm
Hi Tony!
I’m planning to bend it around the skeg then drill through - slather with 5200 - secure with ss through bolts and lock nuts/ washer.
Post by Jaysen » Fri Apr 03, 2020 5:56 am
Look for a sketch grudgeon. They make them. They look just like the pintles.
Actuality called “rudder gudgeon” but mount to skeg. https://www.rigrite.com/Hardware/Rudder ... 20Gudgeons
Class Mini 580 welcome post.
Post by Bogieman » Fri Apr 03, 2020 10:08 am
Thanks Jaysen!
94'325is
Post by 94'325is » Sun Apr 05, 2020 9:24 am
I ordered a pintle and gudegeon from West Marine's outlet store, some of these may work for you:
https://www.westmarine.com/outlet/saili ... rineOutlet
Post by Bogieman » Wed Apr 08, 2020 9:57 am
Thank you!
Post by Jeff » Wed Apr 08, 2020 11:26 am
Bogie, Did you receive the email from me with questions from Jacques to your Sailmaker?? Jeff
Post by Bogieman » Fri Apr 10, 2020 11:20 am
Yes! Thank you very much. Already forwarded to the sail maker👍👍👍
Post by Bogieman » Fri Apr 10, 2020 11:26 am
Rudder and tiller installation complete. A little chafing at the connection but it will be easy to remedy
And I painted the shed to match the house
