Hybird MF14
Chenier
Re: Hybird MF14
Post by Chenier » Sun Apr 07, 2019 5:56 pm
Flipped!
It finally dawned on me that I could build a cradle using the same dimensions as the bottoms of the frames. The height of the cradle is adjusted at each frame by the frame’s difference in height from Frame B. Weatherstripping on top makes it kinder, gentler. You can see the Frame A cradle in this photo.
Chenier
Re: Hybird MF14
Post by Chenier » Sun Apr 07, 2019 5:59 pm
Deck is off. Ready to start epoxying in earnest.
Biney777
Re: Hybird MF14
Post by Biney777 » Tue Apr 09, 2019 2:31 am
Glad the flip went well. She is sure looking good!
Re: Hybird MF14
Post by Jeff » Tue Apr 09, 2019 9:57 am
Nice flip!!! Jeff
Chenier
Re: Hybird MF14
Post by Chenier » Tue Apr 09, 2019 12:12 pm
Thanks, y'all!
Chenier
Re: Hybird MF14
Post by Chenier » Sat Apr 13, 2019 5:23 pm
Gravity is not my friend.
That, and I think I bought the most useless roll of duct tape on the planet! Not only did it not hold the deck on, about half of the tape holding the bottom to the sides came off as well.
So I pushed the bottoms back up with some of the cleats and wedges I'd used earlier.
And judiciously applied some weights to get the panels flush with each other in the center.
Then I "spot welded" the center seam and the bottom-to-side seams with thickened epoxy so everybody will stay where they belong.
Chenier
Re: Hybird MF14
Post by Chenier » Sat Apr 13, 2019 5:31 pm
The nose job came out nicely.
Before:
After:
Biney777
Re: Hybird MF14
Post by Biney777 » Sun Apr 14, 2019 10:25 am
Good job on the nose. Figuring out how to keep the straight parts straight can be a challenge!
Re: Hybird MF14
Post by Bogieman » Sun Apr 14, 2019 1:15 pm
Looking good, Chenier. I like the way you're working through your problems
Chenier
Re: Hybird MF14
Post by Chenier » Sun Apr 14, 2019 4:20 pm
Thanks.
Finished filleting and taping the inside keel seam today. That was good practice! About 40 more linear feet to go ...
Taping the keel inside of the trunk/mast assembly was fun. Thank goodness I'd cut lightening holes - it gave me better access.
