D5 Build
BGinNC
D5 Build
Post by BGinNC » Thu Nov 08, 2018 12:57 pm
This is a quick rundown on where I am on my D5 build. I started the project in February of 2018. I would like to build a larger boat, but I wanted to get my feet wet and make sure this was something I would enjoy doing before I jumped to something bigger. I wanted a cheap project where I could learn some new skills and have fun along the way. IN line with learning new skills, I'm making the sailing
The hull is Baltic Birch marine grade ply. I figured for a trial run, and wanting to be cost conscience, it couldn't hurt. Besides, this boat will probably only be in the water 10-12 times a year.
The mast I made out of a 1x8 clear yellow pine board. I ripped it into (4) 3/4"X1-5/8" strips, put a 3/8" rabbet on both sides, and glued them up into a 2"X2" blank.
It didn't take long to get the hang of working with epoxy and fiberglass.
Mast Cross Section.JPG (22.29 KiB) Viewed 559 times
Re: D5 Build
Post by Fuzz » Thu Nov 08, 2018 1:44 pm
Very nice :!: Thank you for showing it to us. What do you think it is going to weigh when finished?
BGinNC
Re: D5 Build
Post by BGinNC » Thu Nov 08, 2018 1:47 pm
Right now, I'd say it weights about 65-70 lbs. I have to flip it and add seats, mast step, hardware and interior paint. My guess I'll be pushing 90-95 lbs when complete.
Re: D5 Build
Post by Jeff » Thu Nov 08, 2018 2:06 pm
Nice work BGinNC!!! Jeff
Re: D5 Build
Post by terrulian » Thu Nov 08, 2018 2:11 pm
Well done. It sure does look like you got the hang of fiberglass and epoxy quickly! And clearly, you have skills that are up to the job.
Re: D5 Build
Post by Bogieman » Fri Nov 09, 2018 9:08 am
Nice!
Fair WX Pilot
Re: D5 Build
Post by Fair WX Pilot » Wed Dec 12, 2018 9:33 am
It looks great, looking forward to following the rest of your build.
Alan.
Re: D5 Build
Post by fallguy1000 » Thu Dec 13, 2018 5:11 pm
What is the weight per 4x8 of the material you used?
BGinNC
Re: D5 Build
Post by BGinNC » Fri Dec 14, 2018 8:39 am
I believe the Baltic birch is about .7 lbs/sqft for 1/4" and 1.4lbs/sqft for 1/2"
Re: D5 Build
Post by fallguy1000 » Fri Dec 14, 2018 10:59 am
Thanks. When I have some time; I'd like to compare okume.
Users browsing this forum: BlackJack224 and 1 guest
