FS13 Lolyboat
Esoriano
Re: FS13 Lolyboat
Post by Esoriano » Tue Apr 09, 2019 7:49 pm
Thank you for the cheering, today was a very productive day as I have time for preparing the offset of glass fiber around the skeg, sanding the excess of epoxy and the glass fiber which was more than 2 inches of each side
Esoriano
Re: FS13 Lolyboat
Post by Esoriano » Tue Apr 09, 2019 7:53 pm
Then I applied thickened epoxy to all this offset delimited by masking tape like this
Esoriano
Re: FS13 Lolyboat
Post by Esoriano » Thu Apr 11, 2019 9:17 pm
Sanding to blend the skeg to the hull
Esoriano
Re: FS13 Lolyboat
Post by Esoriano » Fri Apr 12, 2019 6:56 pm
After hour of sanding, the fiber glass patch which cover the skeg is totally blend to hull
Re: FS13 Lolyboat
Post by OrangeQuest » Fri Apr 12, 2019 7:39 pm
Hey! I think you missed a spot!! :lol: :lol:
I do not like sanding so much, but you have done a great job. Bottom looks ready!!
Esoriano
Re: FS13 Lolyboat
Post by Esoriano » Sat Apr 13, 2019 1:12 am
I have a question folks, should I paint directly over epoxy or should I apply primer before, the manufacturer of the paint which is a two parts epoxy paint saids on their tech data sheet that could be both ways... also, all the sanding until now was made with 80 grit sand paper, should I use something finer before painting ?
And last, I was thinking in using epoxy with graphite over rub rails what do you think?
Browndog
Re: FS13 Lolyboat
Post by Browndog » Sat Apr 13, 2019 8:57 am
To prepare for paint on the boat projects I’ve done, the final sanding was done with 220 Grit paper. Followed by washing with clean water, then followed by wiping down with clean dry cloths or paper towels. After masking off areas not to be painted, I’ve always used an epoxy primer, which often reveals some unnoticed flaws. Then after a final round of touch ups, fairing and sanding, another coat or two of primer before using the top coat paint.
The epoxy with Graphite powder will slough off slightly when rubbed against something. As a durable rubrail coating it will protect the boat but might leave marks on whatever it rubs against.
Your skeg looks really good. Great job fairing/blending it into the bottom.
Esoriano
Re: FS13 Lolyboat
Post by Esoriano » Sun Apr 14, 2019 9:02 pm
Thank you for the advice, I hope this week have enough time to paint
Esoriano
Re: FS13 Lolyboat
Post by Esoriano » Thu Apr 18, 2019 12:06 pm
I just discover a small hole about less than 1/8” in the hull, when I was ready to paint, what is the best way to deal with it ? Any suggestion?
Esoriano
Re: FS13 Lolyboat
Post by Esoriano » Thu Jul 11, 2019 11:54 pm
Finally I end the hull fairing and sanding and decide to flip the boat to work with all the fairing and paint at the end
