Optimist Club Racer
Re: Optimist Club Racer
Post by tech_support » Fri Sep 16, 2011 3:10 pm
Our local optimist club had a nice write up in the most recent copy WoodenBoat magazine. :!: :)
Also, here is a video of the opti kits posted at youtube...
http://www.youtube.com/watch?v=jwVlLMeB ... re=feedbul
sitandfish
Post by sitandfish » Fri Sep 16, 2011 4:03 pm
shine wrote:Our local optimist club had a nice write up in the most recent copy WoodenBoat magazine. :!: :)
Very nice! Very well done!
And, by the way.... I LOVE the Bateau sticker at the end of the slide show! 8)
bedege
Post by bedege » Wed Feb 29, 2012 12:00 am
Hi there
Very interesting thread that gives a lot of details about building the Opti Club Racer.
I've recently started my own Opti and am wondering about the hole in the mast thwart: what diameter should I bore that hole to?
There's no mention of that dimension in the build guide. :doh:
Thanks for your help :D
bedege
Post by tech_support » Wed Feb 29, 2012 9:01 am
We do not cut that hole because some people will use a plastic liner for the hole, or use a different diameter mast, so we just mark the center with dimple
bedege
Post by bedege » Wed Feb 29, 2012 10:58 pm
shine wrote:We do not cut that hole because some people will use a plastic liner for the hole, or use a different diameter mast, so we just mark the center with dimple
Understand. But,it sounds like I'd better cut that large hole now, before I start my first layer of thin epoxy, right? So, what typical diameter should I use. I looked the optiparts web site, and the plastic liner they offer is 57mm/1.25in in diameter. Is it the dimension I should use?
Any past experience welcome :wink: Thanks
bedege
gstanfield
Post by gstanfield » Wed Feb 29, 2012 11:01 pm
I know nothing about optis and very little about sailboats, however...
I would not cut ANY hole in a boat of mine withough having the part that goes through it in my hand first. It's no big deal to cut and epoxy the hole after the hull is built and you'd hate to build it and then get your mast only to find out that the mast does not fit the hole you cut for it :cry:
Post by tech_support » Thu Mar 01, 2012 9:24 am
If you going to use the plastic liner, then I would get its OD and cut a hole 1/8" bigger. That give 1/16" on each side for epoxy buildup and some play, depending on its size and how far from the hole the screw holes are, you may even drill a 1/4" bigger.
Of course the safe bet it to wait until you have the piece of hardware in your hand. :)
bedege
Post by bedege » Mon Apr 23, 2012 11:40 am
Hi there
Making progress on the built of my Optimist Kit :D
I have a question regarding the gunwale assembly. Looking at the great instruction guide from YSF (http://latitude2739.com/club-racer.pdf), it is mentioned that "knees" are used fore and aft to support the gunwale cap.
How are those created? Should I use left over plywood from the kit and create those part "by hand"? In what order would you advise to assemble the different parts: inside hull strake, doublers, knees, and 2nd inside strake?
Thanks for your support!
bedege
Post by tech_support » Mon Apr 23, 2012 3:20 pm
those parts are not needed, they are parts the local group wanted. It does make a nice finish, but they are not needed and just add more work. You can alway make them from scrap 12mm if you like.
Post by tech_support » Mon Apr 23, 2012 3:22 pm
Oh, and I agree with above, if your going to use the little plastic insert for the mast partner then I would wait until you get the part. Make the hole big enough to account for a couple coats of epoxy.
