Another SK14 Bow Question
Re: Another SK14 Bow Question
Post by Dougster » Mon Jan 02, 2017 9:55 am
I've used lots of S3 and never seen that :doh: I use foam rollers and 1/4" nap rollers from Home Depot mostly. Sometimes I've tipped it with a disposable foam brush, but didn't last time. With nap rollers last week I wanted to tip but had no brushes and still didn't have a problem. I like the too thick mix idea. 4 to 1 ratio and I recall thinning it a bit with water after the pot sat a couple of hours. I'd go after it with the RO and 80 grit too, but with care. Bummer, but a bit of time will fix it. I have two coats on my SK14 now and hand sanded it a bit last night with 180 grit, which took out some of the pin holes.
elementfiftyfour
Post by elementfiftyfour » Mon Jan 02, 2017 4:07 pm
It is Supermarine Etching Primer. I hit it with a 46 grit paper on the long board this morning and it actually sanded down quite a bit so now it is looking pretty decent.
I ordered some foam brushes that I think will minimize the texture.
Post by topwater » Tue Jan 03, 2017 8:37 am
I have only used S3 and never saw a finish like that , that's why i asked. Glad you got a handle on it now. Build on.
elementfiftyfour
Post by elementfiftyfour » Sun Jan 22, 2017 10:56 pm
Slowly but surely.....
I got a chance to put a couple coats of bottom paint on the hull today. Looks pretty decent but am likely to give it a light sanding before flipping over.
Anyone think that a 500 grit sand paper on the long board is a good call or should I just accept the light differences in the roller marks that didn't blend together as much as I wanted?
I'm pretty impressed with myself. It actually took some effort to roll over 4" of masking tape and still get that smudge of paint on the transom. Oh well, it is ganna get painted over eventually anyhow.
Post by Jeff » Mon Jan 23, 2017 6:26 am
Elementfiftyfour, looks really good!! Nice paint work!! Jeff
elementfiftyfour
Post by elementfiftyfour » Sun Jan 29, 2017 2:46 pm
Flipped it over and back to work on the top.
Checking to see what my post looks like.
Drilled a couple holes in the transom supports to let water drain.
Put some final touches on the fairing and cut the hole for my bucket.
Taped and primed it this morning.
Question about the motor and prop depth.
Is this low enough or do I need to get a long shaft motor? This is the Tohatsu 5HP short shaft that I got for my rotomolded SoloSkiff.
tcason
Post by tcason » Mon Jan 30, 2017 9:29 am
really nice build
The motor height looks perfect - but let the experts be the final word................ "ventilation plate level with the keel line"
csotelo
Post by csotelo » Mon Jan 30, 2017 9:30 am
Hi,
I had the same doubt, in tutorials I found this:
Most planing boats will work better with the cavitation plate flush with the bottom of the boat or a little bit above: 1/2" is common.
http://bateau2.com/howto/shaftlength.php
Regards,
Carlos
elementfiftyfour
Post by elementfiftyfour » Mon Jan 30, 2017 3:21 pm
Hi,
Regards,
Carlos
Thanks, just the info I was looking for in relation to such a skinny water boat. I looked over a lot of the build tutorials but apparently missed that one all together.
Post by cape man » Mon Jan 30, 2017 3:53 pm
The motor looks perfect, and if not you can slightly adjust the transom height later a lot easier and cheaper than a long shaft.
I'm glad you flipped it, as I was going to tell you no one will ever see the bottom and it looked great from here. Can't wait to see pics of this baby running! I'm all about small engines on small boats, and I am wagering she will be lots of fun!
