FS14_LS - CSotelo - Brazil
csotelo
Post by csotelo » Wed Jan 25, 2017 6:00 pm
Hello everyone,
I´m building FS14_LS to Peacock bass (Tucunaré) fishing in southeast of Brazil.
I fish in water reservoirs and spots are not far apart. The weather is stable during fishing season and only quick storms are expected in the afternoons.
Here, we use aluminum jon boats (from 5 to 6m + trailer) hard to accommodate in most garages (usually from 4,2 to 5,5m). Smaller models are too light, narrow and tippy.
FS14_LS looks a good choice in my case. I´ll use a carb 15 hp outboard + electric trolling motor. Most times I fish alone or with a buddy.
I´m looking at stickystuff and seaslug builds of same boat and so many others in this forum to get inspiration! :D :D :D
IMGUR Album: http://imgur.com/a/rynkm
Some Pics:
The standard ply sheet is 2,2x1,6m, so nesting was different.
I made all stations and double transom from one sheet of 10mm and bottom and sides from 3 sheets of 6mm.
No way to find wood flour here, I used saw dust and silica to weld the hull.
Silica made it hard to sand and shape. I used coarse a wood rasp, lots of 60 grid sand paper and my fairing "log". 8O
The double transom are too heavy, I made some braces to keep it aligned with strongback.
The seams was easy, but the cloth was a nightmare. :x :x
I tried the wet on wet process, made the seams, pre coated the hull and waited to It cure a little.
When unrolling the cloth it shifted the position and got stuck on wet sticky coat. I had to peel it off and adjust it again and again… almost lost the cloth. :x
From coating to wet both sides it took me 8 hours… 8O
The fishing spots I go are full of logs or rocks, so I glassed the sides with same cloth for extra protection.
Sharpening the chines
The rub rails will are made of eucalyptus (2x 5x1 cm).
It was very hard to bend then in the bow, I had to use boiling water to soften the wood in some places.
I had to pause the build due to family health issues and will restart in a week.
I´ll finish the rub rails and start the fairing.
As fairing compound I´ll use silica and hollow glass spheres.
If you guys have any hints I´ll be glad to listen.
Thanks!!
Re: FS14_LS - CSotelo - Brazil
Post by Jeff » Wed Jan 25, 2017 7:09 pm
CSotelo, great build and excellent documentation of your work!!! Please update us when possible!! Jeff
csotelo
Post by csotelo » Wed Jan 25, 2017 8:04 pm
Thanks Jeff!
seaslug
Post by seaslug » Wed Jan 25, 2017 8:15 pm
Very nice job on the glass work, even with the problems you had. I can see this is going to be a nice boat when finished. Keep up the good work. Mike
csotelo
Post by csotelo » Fri Jan 27, 2017 8:11 am
Thanks Mike!
I´m sure I´ll copy your hatches design!
csotelo
Post by csotelo » Fri Mar 03, 2017 4:35 pm
Hello everyone,
I finished the rubrails and made the bed to u-bolt in the bow.
Working on fairing now... really boring part. Every time I fill a low spot, two more are created... Worst part till now.
I´m using 2 spreaders, one 15cm and a large 40cm. The fairing putty is 1 part silica, 4 parts hollow glass spheres and resin (10gr+40gr+300gr). I do long passes with large spreader and fix some areas with smaller.
I´m using a 6mm ply fairing board and a hand sander with 60 or 80 grid. After knock off the high spots I smooth everything with a RO sander with 60 grid.
Do you guys have any hints?
Thanks!!
Post by Jeff » Fri Mar 03, 2017 5:22 pm
Very nice work CSotelo!! Jeff
Post by Dougster » Sat Mar 04, 2017 9:05 am
Sure looks good to me. I work the same way: long board for fairing, RO sander for smoothing. It's tedious and I just go 'till I can't stand it any more and then finish smoothing with the RO one last time. I tend to quit too soon :oops: You've pushed through the hardest part I think. What primer will you use? If you can get S3 it sure is easy to work with.
Post by Eric1 » Sat Mar 04, 2017 1:09 pm
Really nice work! That will be a great boat!! 8)
csotelo
Post by csotelo » Mon Mar 06, 2017 2:29 pm
Hey,
@Jeff, thanks!
@ Dougster, Thanks! I feel the same, always trying to get strengths to change the longboard sand paper one more time before go to RO. :lol:
I made one more fairing session this weekend (longboard, RO, putty again). After the next one I think just shaping the corners will be missing.
I don´t have access to S3 products here, I´ll use International's. Intergard EPA 632 primer and Perfection 709 paint. Even those are not easy to find.
I´m just wondering how primer cover scratches and pin holes... I´m looking at you SK 14 to get some ideas, It´s looking very good!
@Eric, Thanks! I saw you C21, looks great! I can´t imagine how hard must be fair a big boat like that!
