FS14_LS - CSotelo - Brazil
csotelo
Re: FS14_LS - CSotelo - Brazil
Post by csotelo » Fri Jun 09, 2017 10:33 pm
Thanks Jeff!
Thanks, Eric and it´s just a glove thumb covering the chase tube ! :D :D
csotelo
Post by csotelo » Sun Jun 11, 2017 10:06 pm
Hello,
I made some progress this weekend.
I drilled the ubolt holes on transom, the bolts are 10mm, I drilled 14mm and will fill, re-drill.
Now I´m working on gunwales. They will be strait and the size plans indicate. I´m trying some hod holders mock-ups to decide how to make then.
I appreciate any inputs in this subject. :D
Thanks!
Gunwales
Ubolts
cape_fisherman
Post by cape_fisherman » Mon Jun 12, 2017 3:33 pm
I don't like rod holders to be in-line on the horizontal. If I want the outboard rod, I would have to remove the inboard rod, get the other one out, and then replace the first rod.
csotelo
Post by csotelo » Mon Jun 12, 2017 4:49 pm
I know, but I don´t have much choice.
I´ll put some vertical ones to rest the rod to get the fish on boat, but to me is a problem let it there and cast. I broke one rod in 45° holder in my kayak.
Also it´s very common to have thunder storms and carbon rods are very conductive, we don´t even fish during then. 8O 8O
This was last year, me my brother end a guide, sunny day. We got 30 min of thunders and then everything back to normal.
One hour later:
Post by Jeff » Mon Jun 12, 2017 4:52 pm
Nice catch after a little rain!! Jeff
cape_fisherman
Post by cape_fisherman » Tue Jun 13, 2017 1:16 am
One hour later:
No, I didn't mean gunnel/flush mounted rod holders. I was strictly referring to the under gu nel storage you have. Keep them in the same location...just store them one above the other instead of beside one another.
Post by Eric1 » Tue Jun 13, 2017 6:09 am
Carlos, He means like this. Left side of photo.
http://gallery.bateau2.com/displayimage.php?pid=28631
csotelo
Post by csotelo » Wed Jun 14, 2017 9:50 am
I got it, I´ll try to mockup something like this.
There´s no much space under gunwale (about 21cm) but I think it can fits 2 small baitcasting reels.
Thanks guys!
csotelo
Post by csotelo » Wed Jun 21, 2017 6:11 pm
Hello,
I tried to put the rod holders in vertical, but no chance.
With just 21cm, even the small baitcasting reels touch the sole, so I´ll keep then horizontal.
I cut the parts, made the hole and fit the tubes.
Also decided to drain the cockpit to transom with a 20mm PVC tube filleted and glassed to the hull. If it cracks the glass will hold it a little.
Now I´m fairing again... :? :?
Need to get this and motorwell done to close the decks.
This time I´m using a very loose putty in thin layers in a hope to avoid sanding.
Post by Eric1 » Wed Jun 21, 2017 6:17 pm
Carlos, Sorry the vertical rod holders didn't work for you. Your boat is looking really nice.
Maybe your fairing trick will work. I tried that but I still had to sand.
Keep Rocking!!
Users browsing this forum: _Martin, nathan and 2 guests
