FS14_LS - CSotelo - Brazil
Re: FS14_LS - CSotelo - Brazil
Post by Eric1 » Wed May 03, 2017 3:39 am
Carlos, You are doing a great job with the boat! 8)
csotelo
Post by csotelo » Sun May 07, 2017 7:17 pm
@Eric! Thank you my friend!
This weekend with intermittent rain was a PITA to work in the boat, it´s secured from it but everything from my waist down got wet :x :x
I did the bow framing as indicate by Seaslug. Every part passed to "Stand on it" test :lol:
I also did 2 coats of tinted epoxy and doesn't liked the results. It´s supposed to be "Sand" color but looks white and don´t cover too much.
Now I´m dry fitting the stern parts.
I cut a slot in the transom, just the glass and first layer of ply (about 3mm) and it holds the beams really good.
The under sole will be filled with EPS boards. No way to get 2 part closed cell foam here and local builders use EPS or other weird things
(ex: plastic Coke bottles) to get flotation.
I made a test with caned foam to fill gaps and it glued well on EPS. I don´t want the EPS blocks free and banging around.
Post by cape man » Sun May 07, 2017 10:42 pm
Looking great.
Post by Eric1 » Mon May 08, 2017 4:32 am
Carlos, You are doing a great job on the build. I wish you could get the foam but you are adapting and overcoming. Sometimes you have to do with what you have. Rock on Brother. 8)
csotelo
Post by csotelo » Wed May 17, 2017 4:14 pm
Thanks Cape Man and Eric!
I had a lot of work on past weekends and didn´t got much done.
But I got chase tubes installed, EPS blocks glued, sole backing plates glued and 3 coats of epoxy.
Now I´m planning the motorwell. A lot of doubts about it. I opened a separate thread an any inputs will be helpfull!!
viewtopic.php?f=1&t=62251&p=395536#p395536
Thanks!!
Carlos
Some pics
Chase Tubes:
EPS dry fitted:
I calculated 160 liters of EPS plus a small can of foam.
Sole glued and coated. The blue masking tape don´t soak in resin and I could remove it after 2 days.
EPS cut outs for backing plates.
The sole drain recess as Seaslusg did in his boat:
Post by Eric1 » Wed May 17, 2017 6:35 pm
Good to see you posting! The Boat is coming along nicely too!
csotelo
Post by csotelo » Tue Jun 06, 2017 10:14 pm
Hello,
A lot of work and heavy rains are keeping out of build, but I did some progress.
I glued the stern frames.
Now I´m dry fitting the motorwell and backing plates for seat pedestal.
I think 3 layers bond together will be enough. It´s not as good as the ply I used in the hull but survived to boil test.
I also got the cooler, it will be a seat and a casting platform. Now I can place a ring or something on the sole to get it tied.
It´s the local version of YETI and survived to more than 300 pounds over it :lol:
csotelo
Post by csotelo » Fri Jun 09, 2017 6:00 pm
Hello,
I got some time after work to glue, tape and glass the sole. I´m using 100g/m2 cloth to cover the sole and the rest of the boat, it´s really easy to wet.
I´m thinking use a 20 mm PVC tube to make the cockpit drain to transom, any concerns about it?
Thanks!
Post by Jeff » Fri Jun 09, 2017 7:09 pm
CSotelo, really nice glass work!! Jeff
Post by Eric1 » Fri Jun 09, 2017 9:31 pm
Very Sexy! Carlos!! 8)
