FS14_LS - CSotelo - Brazil
Re: FS14_LS - CSotelo - Brazil
Post by Jeff » Fri May 18, 2018 1:03 pm
csotelo, looks good and I like the color!! Jeff
Post by Eric1 » Fri May 18, 2018 1:06 pm
Carlos!! That look incredible!! :D 8)
Post by Fuzz » Fri May 18, 2018 3:12 pm
Looks like your paint plan worked. Very nice looking job and way better than before :D
Post by cape man » Fri May 18, 2018 8:43 pm
That looks fantastic!
Post by OrangeQuest » Fri May 18, 2018 8:50 pm
Looks like it still is wet it is so smooth!
csotelo
Post by csotelo » Thu Jun 21, 2018 11:44 am
Thanks guys!
I flipped the boat, masked, did some fairing and primed the decks.
After my experience with this paint, I don´t think will be a good idea mix silica or anti-skid additive on it.
I´m testing a rubberized paint used in car´s underbody and metallic roofs. It makes a good texture, don´t slip when wet, easy to wash.
Not to strong, I can dent it with a screw driver, but not with my shoes. It can be repaired with no special preparation, just wash, dry and paint.
I´m considering paint with white Perfection PU and use white rubber paint in anti-skid areas direct over primer, and the black on rub rails.
What you guys think?
Post by Eric1 » Thu Jun 21, 2018 1:38 pm
I think it looks great! Congratulations on your flip! :) 8)
Post by Fuzz » Thu Jun 21, 2018 6:58 pm
I think that gray paint will work out well. Just enough texture and not too much.
Post by OrangeQuest » Thu Jun 21, 2018 7:10 pm
It will also keep the sun from reflecting back and blinding you.
csotelo
Post by csotelo » Thu Jun 21, 2018 8:14 pm
The first board has 3 coats of white, looks gray in the shades. The others has 4 or 5 coats
I can mix some black in it to make it gray, it accepts water based tints.
Thanks for the hints!
