SK14 build in NC
BrianC
Re: SK14 build in NC
Post by BrianC » Wed Mar 15, 2017 1:03 pm
A finishing nail hammered through a small block of wood makes a great spacer. Inserting these between the panels gives the gaps you need - the wood blocks (~1" square) holds the nail vertical in the gap.
That said, this isn't too important for a hull design for relatively low power engines.
Brian
Post by Dougster » Thu Mar 16, 2017 11:05 am
Looks OK to me. Once I had panels jammed up against each other too tight and just ran a saw down the joint, moving the zip ties as I went. The nail/wood block idea sounds better than my popsicle stick way. I'm always learning something new here.
cape_fisherman
Post by cape_fisherman » Thu Mar 16, 2017 4:35 pm
Don't overthink it...you'll be fine I believe.
Users browsing this forum: fitzclf and 1 guest
