D5 Build
Parkrat
Re: D5 Build
Post by Parkrat » Thu Feb 22, 2018 9:14 pm
jacquesmm wrote:
Thu Feb 22, 2018 2:45 pm
Do you guys think I need a skeg?
The designer thinks you need it, that's why it is on the plans. :D
In this boat, it is not a stiffener but it is important for tracking even with an outboard.
Why would you remove it?
I had a slight lapse in judgement. :D
Got the doors on the steam box. Slowly getting there...
OneWayTraffic
Re: D5 Build
Post by OneWayTraffic » Fri Feb 23, 2018 2:01 am
I will add that if you plan to row much that skeg could be a bit bigger unless your skills are better than mine. I gave up rowing after one attempt and use outboard and paddle. It’s all you need really.
Re: D5 Build
Post by terrulian » Fri Feb 23, 2018 10:10 am
Well, there's rowing and there's rowing. I don't think you'll make three knots with a paddle and a mile will be very tedious. If you are really going to use your own muscle with no outboard for anything longer than 100 yards, I would go with real oars and the skeg size the designer specified. What's the downside?
Parkrat
Re: D5 Build
Post by Parkrat » Fri Feb 23, 2018 6:00 pm
We probably will be rowing here and there for fun. We do want to put oar locks on it. I'll be towing it behind my boat for long weekends anchored out. Might just use oars to get to shore. I bet it would tow better with a skeg too.
Re: D5 Build
Post by ks8 » Sun Feb 25, 2018 9:35 am
Go ahead and do some quickfair. :) All will be glad you did. Recognizing a taped hull is one thing, but seeing the biax weave clearly, with unfilled deeper areas, is another. Maintenance will also be easier if there is a smooth faired surface over the tape, even if one can still recognize a taped hull structure. Do some quickfair or other fairing compound, even if it is minimal, imho. :D
Re: D5 Build
Post by ks8 » Wed Feb 28, 2018 10:42 am
And... if you ever flip in the water (may it never be), the skeg is something to grab hold of for a grip and for leverage to correct the situation. At the leisurely displacement speed of a D5, you want that skeg. You may find that the vee isn't deep enough to adequately stabilize the tracking of a short and wide hull like the D5, without some sort of minimal skeg. Don't want to find that out after launching, when it is plenty easy to bond it on now at this stage. That vee will help slightly ease some motion and slapping in a "sea", but I suspect that even the small skeg will help the tracking more than that vee alone ever could. Just think of how much even a small rudder helps with tracking, and how steering becomes a creative challenge without a rudder. The skeg is your friend. :)
Planing boats when up on plane, might do with only some strakes, and no "skeg", but if they have the strakes it is likely because they need them for tracking. On a D5, its a skeg. :wink:
Parkrat
Re: D5 Build
Post by Parkrat » Fri Aug 09, 2019 8:58 am
I've been slowly working on the D5, but haven't had much time to post and put pictures together. I did take pics and will post of the progress. For now I have a question about my african mahogany rub rail and motor clamping board. After many attempts I finally got 2 pieces steamed and formed around the hull. I took some leftover scraps and laminated them together for the clamping board. Trying to decide how to finish them.. Question is what would be the best way? They won't get much abuse at all. Thought about several layers of epoxy then several layers of varnish. Or just many layers of varnish. Just epoxy? The inside will be the Pettit EZPoxy white and the outside is the Platinum.
Also, trying to decide the best way to mount the clamping board. Not sure I want to epoxy glue it to the hull like the rub rails. If I through bolt them together I could always remove them to replace etc.
Any thoughts are appreciated! Oh yeah.. here are some pics. :D
Re: D5 Build
Post by jacquesmm » Fri Aug 09, 2019 9:27 am
Very clean job. Thanks for the pictures.
Re: D5 Build
Post by Jeff » Fri Aug 09, 2019 9:37 am
Beautiful work!!! Jeff
Re: D5 Build
Post by terrulian » Fri Aug 09, 2019 11:48 am
Great work!
Not sure I understand the question on rub rails, but if you coat with epoxy you need something on top for UV protection. Of course, many boats have been simply varnished before we had epoxy.
I glassed my rub rails and unless you have a rubber rail attached to them, I'm not sure I'd agree that they won't get much abuse. Even with the rubber rail on the exterior, the top of the gunwales will get whacked by oars and loading people and gear aboard.
