D5 build/new member intro
Re: D5 build/new member intro
Post by Jaysen » Mon Sep 25, 2017 2:34 pm
I'd consider sitting on the aft seat the first sail or two so you know where you want the sheet block. JM recommended holes or pegs in the knees and using that for the sheet. If you look at my Lil Bit, I put some rings in behind aft frame and that is really close to perfect IF I go "across the hull". A few minutes might give you all the info you need.
Netpackrat
Post by Netpackrat » Mon Sep 25, 2017 2:42 pm
Sure, it's only a 128 page thread... 8O
Post by Jaysen » Mon Sep 25, 2017 3:25 pm
Hey, got to do the work to learn :P
3/8" hole in the frame (epoxy coated) with line through. Allows tie off for things (like anchor, sheet, fenders, etc) as well as sheet rings (on the end).
Ignore the dirt. She'd been fishing :)
1297
1298
1299
Netpackrat
Post by Netpackrat » Mon Sep 25, 2017 3:59 pm
Well, so far I have learned that it's important to read the plans carefully. :wink:
Post by terrulian » Mon Sep 25, 2017 5:35 pm
Jaysen uses a 3/8" hole but I think mine are either 1" or 1.25" so I can accommodate more than one line or a strap and easily tie a round turn.
Post by Jaysen » Mon Sep 25, 2017 6:10 pm
Don't READ my thread... just look at the pictures...
Correct. I didn't want to have lots of lines, just one that I could put under tension. I'll be adding a second line if I ever get time alone with her again. Or maybe I'll go fishing...
