D5 Build
BGinNC
Re: D5 Build
Post by BGinNC » Sun Jan 27, 2019 3:42 pm
Well, I’ve made some more progress. I have the seats installed, the inside faired and painted. I still have to paint the rudder and the dagger board, and varnish all the bright work. I purchased a sailrite sail kit for it and have the sail sewn together as well. I just need to get a #2 spur grommet die set to finish it.
Re: D5 Build
Post by terrulian » Sun Jan 27, 2019 3:59 pm
Great progress!
1) How are you planning on sealing the hatch cover?
2) Is the hole in the forward bulkhead going to have an access port?
3) Will you need a limber hole on the bottom of the forward bulkhead to drain water ingress from the partners?
BGinNC
Re: D5 Build
Post by BGinNC » Sun Jan 27, 2019 4:40 pm
I’m just going to install a latch. The cover won’t be sealed. The forward bulk head hole will not be covered. I do have limber holes in the mast partner on the back side of the forward bulk head. Since it is easy to reach everything, Any water I will just mop up with a towel or sponge when I load it on the trailer (which I still need to get).
Netpackrat
Re: D5 Build
Post by Netpackrat » Wed Jan 30, 2019 9:35 pm
Curious to know what you did to protect your mast step box since in theory this is a high wear area due to mast rotation. Did you glass prior to assembly or just seal with epoxy? For mine I ended up making a fiberglass tube around an aluminum tubing mandrel, with the bottom end closed up by thick laminate, with the the tube bedded in cabosil/milled glass fiber putty. I added a drain tube out the bulkhead to keep it from filling up with water. This allowed me to use a sealed cover and make the area under the seat into dry storage.
BGinNC
Re: D5 Build
Post by BGinNC » Thu Jan 31, 2019 1:55 pm
The mast step is just coated inside with three coats of epoxy.
BGinNC
Re: D5 Build
Post by BGinNC » Sun Feb 03, 2019 6:56 pm
I was able to wrap up al the loose ends except for sail grommets. I can’t wait to get her in the water!
jtdums
Re: D5 Build
Post by jtdums » Mon Feb 04, 2019 6:13 am
What will your "home" waters be for this nice boat?
Sanding is cathartic...
BGinNC
Re: D5 Build
Post by BGinNC » Mon Feb 04, 2019 12:15 pm
Probably High Rock Lake as well as a few municipal reservoirs that are a little closer to home.
Re: D5 Build
Post by Jeff » Mon Feb 04, 2019 12:50 pm
Really nice work!!! Jeff
Re: D5 Build
Post by terrulian » Mon Feb 04, 2019 1:17 pm
Looking good. Almost in the water! :D
I still am not seeing the limber hole(s) you mentioned.
I'm not so concerned with drainage at the dock as I am with recovering from a capsize and then bailing. That's why I asked about the latch on the aft locker and the hole in the forward bulkhead.
