GV10 Stop and Start Project
MikeyGnz
Re: GV10 Stop and Start Project
Post by MikeyGnz » Sun Jun 09, 2019 3:17 am
Back from my holiday and recovered ready to start building again. Hopefully I will start assembly next weekend.
MikeyGnz
Post by MikeyGnz » Sun Jun 09, 2019 3:21 am
Netpackrat wrote:
Fri May 24, 2019 2:12 pm
MikeyGnz wrote:
Mon Mar 18, 2019 3:42 pm
Gas/air cooled size 26 torch. I would love a water cooled but don't really do enough welding at high enough amps to make it worth the cost.
Was going through this thread again for ideas, and thought I would mention I have been told if you have a faucet and drain in your shop, you can get a fitting to hook a water cooled torch up to your faucet, and then run the outflow right back into your drain, and thus avoid the cost of a radiator and coolant setup.
I have thought about that but from what I have read it reduces torch life. 2 main issues:
  • Heat from the torch boils off some of the water leaving deposits in the cooling passages.
    Torch internals are brass and brass is attacked by chlorinated water.
As well as that I would have to run a lot of hoses as there is no water in my workshop.
In truth the air-cooled torch is all I need, I just want more toys.
Post by BB Sig » Sun Jun 09, 2019 1:07 pm
Isn't that the truth in most of what's on forums?! :lol:
MikeyGnz
Post by MikeyGnz » Tue Jun 11, 2019 9:49 pm
Philosophy time
Is a home built boat 'just a toy' or is an expression of self, creativity and skill?
The things I have to tell myself to rationalise building one.
Post by Jaysen » Tue Jun 11, 2019 10:11 pm
It is whatever you need it to be to justify the build.
Class Mini 580 welcome post.
MikeyGnz
Post by MikeyGnz » Mon Jun 24, 2019 5:42 pm
No pictures but have been arranging things all ready to start stitching together. Should see some progress this week.
Post by Jeff » Tue Jun 25, 2019 8:41 am
Get us some photos when you can MikeyGnz!!
MikeyGnz
Post by MikeyGnz » Sat Jun 29, 2019 7:04 pm
Nothing interesting to show Jeff. It was all just small odds and ends like buying tie wire to stitch with. Buying pipe and cutting to short lenghts since i have seen others use that in their stitches.
Started some actual boat work yesterday. Welds on panels ground flat. Rivets holding frames together for welding drilled out. Rivet holes welded up. Found one dodgy weld on a bottom panel and rewelded that. Was too lazy to go and get camera, especially as it is still just a pile of panels like in the last photos so nothing to show.
Today it will be stitched, and there will be photos.
MikeyGnz
Post by MikeyGnz » Sun Jun 30, 2019 6:00 pm
I was wrong. Much more prep required than I anticipated, then I ran out of screws. To continue tonight.
MikeyGnz
Post by MikeyGnz » Mon Jul 01, 2019 7:38 am
Finally some progress. Frames assembled and mounted on sawhorses, sides screwed in place.
Bottom panels fitted with temporary stiffners and drilled for tie wires.
Transom drilled for stiffeners and ready to fit. I will attach stiffeners once fitted.
And since everyone else puts up a selfie but I hate having my photo taken
Note: Don't weld with the torch pointing back at yourself. I was wondering what the burning smell was. Luckily just the helmet and not me.
