V-10
Beowulf
V-10
Post by Beowulf » Fri Jun 24, 2005 9:47 pm
Hey,
I was going to build the d4, but I changed my mind, and I am now going to build the V-10. Why? Because the V-10 has more fishing room.. I got the plywood, tape, roller, etc. However I need more epoxy so I might have to wait till it comes to start building. I still plan to mount a trolling motor on it until I can afford a 5hp regular motor.
Beowulf
Note: Please delete my D4 thread.
Beowulf
v-10
Post by Beowulf » Fri Jul 08, 2005 2:53 pm
Well, my brother and I drew, and cut the panels. We also glued the butt blocks on today. We are hoping to stitch it on Sunday. Epoxy is the messiest stuff I have ever used. I almost ended up glueing my sock to the floor when I went down to close the windows.
Barney
Post by Barney » Sun Jul 10, 2005 10:42 pm
Good to hear you're underway, Bewulf! Remember to take some pictures along the way so we can see where you're up to! Looking forward to seeing your V10 take shape.
Beowulf
V-10
Post by Beowulf » Mon Jul 11, 2005 2:55 pm
Thanks Barney,
We stitched the boat today, and filled all the tiny gaps with epoxy. It took us a while to get the steep curve at the bow, but we finally did.
Barney
Post by Barney » Mon Jul 11, 2005 6:02 pm
I certainly had a bit of trouble getting all four panels of my V12 to fit together neatly at the bow as well. I ended up having to do a fair bit of fileing of the edges of the panels to get them to sit flush against each other. On one side, it just wasn't possible without unstiching the whole boat and recutting the panels, so I glued it all together and shaved off the overlapping bits of the panels with an angle grinder.
That's what I love about this type of boat building - no matter how bad a mistake you make (within reason), with a bit of time and thought you can always recover and end up with a good result!
Beowulf
v-10
Post by Beowulf » Thu Jul 14, 2005 2:24 pm
Well,
Iv'e been working on fiberglassing the inside. I have gotten to the bow so far. I bought a 40lb. Minn Kota trolling motor today for the boat.
HokieBoatbuilder
Post by HokieBoatbuilder » Fri Jul 15, 2005 9:15 am
I think you can post your pictures now. Here are instructions on how to do it. http://64.251.22.171/phpBB2/viewtopic.p ... to+gallery
Good luck fiberglassing.
-Taylor
FL14
Beowulf
V-10
Post by Beowulf » Tue Jul 26, 2005 9:10 pm
Hi,
I finished fiberglassing the inside. Tomorrow I plan to sand the outside and fiberglass it. I am hoping to get some pictures on here soon.
Beowulf
V10 Pictures
Post by Beowulf » Wed Jul 27, 2005 4:48 pm
Beowulf
V10 Pictures
Post by Beowulf » Wed Jul 27, 2005 7:50 pm
Well , my brother and I sanded and fiberglassed the outside. Here are the pictures.
